Sunroof?
Old Jun 11, 2007 | 07:03 PM
ech0sh4y's Avatar
ech0sh4y
Sunroof?
Do you guys know if it's a smart idea to put a sunroof in? This and powersliding rear window (wich i might end up doing) are the only options that my truck has that i wanted... my friend says it's a dump idea cause they tend to leak.. anyone do this or have thoughts on it?
Brian
Old Jun 11, 2007 | 08:37 PM
brad3384's Avatar
brad3384
I have both in my 06 screw and I have not had any problem with any one of them.
Get them both you will love them.
Old Jun 11, 2007 | 08:40 PM
brad3384's Avatar
brad3384
After reading your post again my sunroof and power slider both came factory installed.
Old Jun 11, 2007 | 09:06 PM
ech0sh4y's Avatar
ech0sh4y
yeah i'm jelous =*(... but do you know if you can still install the OEM or maybe aftermarket is better? with out issues?
Old Jun 12, 2007 | 07:51 AM
slash12376's Avatar
slash12376
Try this place. I have heard alot of good things about them. They can usually install the OEM sunroof with a warranty or an aftermarket sunroof as well.
http://www.classicsofttrim.com/locations.html
Old Jun 12, 2007 | 05:55 PM
Dustin1690's Avatar
Dustin1690
Where there is a possibility of it to leak but not if its in properly plus they are nice!..
Old Jun 12, 2007 | 06:30 PM
ford390gashog's Avatar
ford390gashog
You won't be able to add the oem sunroof, you will have to go aftermarket. My local dealer uses aftermarket ones and I think the fit and finish sucks. The factory unit has extra cross supports welded to the upper roof. The aftermarket ones don't and the roof tends to flex a lot. It also just looks wrong.
-Hilgy-
Mar 7, 2011 01:01 PM
ArtTruex
Jun 23, 2008 04:48 PM
anthonyh75
Nov 17, 2006 03:03 PM
sonic
Apr 26, 2004 12:58 PM
packlet
Dec 4, 2003 07:56 PM
