E250 1992 ENG light on
Old Jun 11, 2007 | 05:35 PM
inventor's Avatar
inventor
Hi I have a 1992 E-250 ECONOLINE L6 4.9 Liter FI and the check ENG light is been on for the longest time 2 years, I had cold start problem and change the IAC and temp sensors replaced, the cold start went 70% a way but today went for smog test and all pass but the technician because the EGN light remains on i had to fix it before passing it. any ideas?...............thanks
Old Jun 11, 2007 | 06:25 PM
Bear River's Avatar
Bear River
Former ******
What are your codes? Pull the codes from the computer and post them here and we can point you in the correct direction.
Old Jun 11, 2007 | 06:32 PM
inventor's Avatar
inventor
Thanks ....but I have no codes I guess i have to go to a shop and have it tested?
Old Jun 11, 2007 | 08:00 PM
subford's Avatar
subford
No do it your self.
Just ground the STI input and count the flashes from the CEL.
To check your codes go to one of these links below:
This is good for the KOEO test:
http://fordfuelinjection.com/?p=13
This one is good for the KOER test:
http://www.broncodata.com/tech/codes.htm
Old Jun 12, 2007 | 01:51 PM
inventor's Avatar
inventor
[QUOTE=subford]No do it your self.
http://www.broncodata.com/tech/codes.htm[/QUOTE]
Well I tell you this code counting is like a Morris code and I thing i have counted right.....here it goes.
118,118,118,1,118,172,332,118,172,332
I give you all the codes the way they came out.
And I found the explanation on this site, let me know if is OK?
http://www.actron.com/user_manuals.php
Under this... Ford Code Scanner CP9015
Thank you... thank you
Old Jun 14, 2007 | 04:36 PM
JohnMcHugh1's Avatar
JohnMcHugh1
Check Engine Light Code reader
Auto Zone, maybe Pep Boys, others, will take the reading for you, seeking to sell you the items in the path to resolution. Always look over the shoulder and make a good record of the exact number(s), and there may be several listed, sequentially. There may also be a suggested 'fix' given, which I am sure you will be told as gospel.
Come back on the forum with the numbers, and someone will be able to help you (not me, I am a novice).
Old Jun 14, 2007 | 04:43 PM
JohnMcHugh1
Cel
Check engine light, if on when there is not a problem, can be reset via battery disconnect, allow to sit 1/2 hour, or leave lights on until they fade fully, then reconnect battery (try Negative cable disconnect only).
The system will reset, and if there are no faults, then no lights! Maybe you want to do this about 5 minutes prior to getting the thing inspected, so the CEL does not alight anew...just out of habit.
Old Jun 14, 2007 | 04:44 PM
inventor's Avatar
inventor
The numbers are posted ubove BTW AutoZone and others only check 1996 and newer.....
Old Jun 14, 2007 | 04:48 PM
inventor's Avatar
inventor
thanks I will try this now and report back ........
Old Jun 14, 2007 | 05:20 PM
inventor's Avatar
inventor
Here you go what you thing.......
Old Jun 14, 2007 | 07:28 PM
Club Wagon's Avatar
Club Wagon
Keep asking, that is often what they tell you, but they often are capable of reading fault codes on OBD-1 vehicles.
In my town I found Pep Boys was the only one that said they could read OB-1, but discovered Advance also had the device to do it too.
I finally broke down & invested in an Innova 3145 digital code reader after being told they could not read fault codes unless the CEL was on! Counting & recording flashes is no fun. IMO it was a bargain & one of the better ebay deals. My intermittent problem was illuminating the CEL inappropriately & not often.
Old Jun 14, 2007 | 08:07 PM
inventor's Avatar
inventor
this code readers do the same thing you can do "count" so I video tape the test and than sat down and count in my lesser.
Old Jun 18, 2007 | 07:00 PM
inventor's Avatar
inventor
Thumbs up Check engine light on
<TABLE><TBODY><TR><TD vAlign=top width="100%">Problem solved.
First I like to thank all who helped.........
This is FYI.... What I did fist remove the neg. battery cable and reconnect 1/2 later next started the ENG and run it for 2 min. Next check the code again and guess what now I had one code to deal with the ECT sensor [the last batch of codes i posted here wer left overs] and would know it I had this sensor replaced 8 months ago and the wire going to it had one of this useless snap on connectors the wire was cut and barely touching after conecting it the ENG light turnd off. So the smog test OK and....... thanks again.......
</TD></TR></TBODY></TABLE>
