05 Diesel Excursion A/C
Old Jun 11, 2007 | 05:15 PM
tbaste's Avatar
tbaste
Just bought an 05 Diesel Excursion last week and the front vents are acting up. All vents work fine with the exception of the front ones, working here and then, but seldom. I've been told it's a loose vaccuum problem. Any help on where to look? Thanks!
Old Jun 12, 2007 | 07:50 AM
Brians97F250Crew's Avatar
Brians97F250Crew
roll that sucker up to a dealer and tell them to fix it. One place to check for a loose connection is under the hood on the heater cut off valve.
Old Jun 15, 2007 | 05:00 PM
tbaste's Avatar
tbaste
Thank you for the 411. After digging around for info, found out the problem is the electric pump (apparently diesels do not have vaccuum pumps) that supplies the equivalent of vaccuum to the A/C system. They are located directly behind the passenger side battery and apparently stick and would have to tap it a few times to unstick it. Seems as this is a common problem for Ford Diesels, which causes the air to push out instead thru the defrost vents rather than the front vents. Hope this is useful to all diesel owners with the same problem. Thank you!
