Front Quad Shock Bracket but Only 2 Shocks
Am I missing some parts here? I bought a 1995 Bronco a while ago and when I had the radius arm off I wondered what the bracket was that shares the same bolts but goes towards the front of the axle. It had a stud fixed to its face but it didn't seem to actually /do/ anything. While looking something else up in my reference CD I see that it is the mount for the front shock in a quad-shock setup.
When I was looking it over before I bought it I looked into the wheel well, saw only one shock each side and figured that was that, but now I am not so sure. Did Ford put that bracket on ALL the Broncos or just the ones with the Quad shock option? If this really was originally a quad shock truck then do I need to get it back to two each side when I replace the shocks? Shocks are next on the list anyway.
Calvin
Calvin
Originally Posted by Gacknar
Does the spring/shock tower have a place to mount a shock in forward of the spring like it does after it?
Calvin
Ford didn't put them on all trucks . None of my 94-95-96 have then unless quad set up. They may have been using up parts. Or the front end was plowed and replaced with quad parts .
It doesn't matter When you go to replace Coils shocks just get the quad spring buckets and bolt on. I'd check another truck with quad to see if the mount is shock first.
Good luck LOST
Good luck LOST
JRS2
11-28-2015 07:22 PM
juddspaintballs
03-19-2015 07:24 AM
S_Bruce
05-23-2007 07:39 PM
caddywhompus
1978 - 1996 Big Bronco
01-12-2004 08:38 PM
