Sponsored by: Real Truck
Engine stalls when in reverse or low
Old Jun 11, 2007 | 11:06 AM
OHorn's Avatar
OHorn
I have a 97 250HD powersrtoke that stalls when i shift into reverse or low when the engine is warm? E40D tranny with 180,000 miles, I replaced the speed sensor and the speedo odommeter module and flushed the tranny? Thanks for looking!
Old Jun 11, 2007 | 11:41 AM
redford's Avatar
redford
FTE Leadership Emeritus
Welcome to FTE!
Did your truck do this before you flushed the tranny and replaced the speed sensor and the odometer module?
Have you scanned for error codes?
Old Jun 11, 2007 | 11:44 AM
OHorn's Avatar
OHorn
Yes it did and I have scanned the codes only to find the speed sensor bad which I replaced?
Thanks!
Old Jun 11, 2007 | 11:53 AM
redford's Avatar
redford
My first impulse when someone is complaining about a 7.3 PSD stalling (for any reason) is to recommend a CPS replacement, but I would hold off a bit and see what others say.
Old Jun 11, 2007 | 06:00 PM
roninboy's Avatar
roninboy
&.3 trouble
I am having a problem. My 7.3 PDS on my 99 F-250 SD, is almost like a miss. The motor is running I am doing 65mph and it will sutter as if the motor shut down for a brief second. It has also done it at lower speeds. It has stalled once. My nieghbor metioned the (CAM SENSOR)????? is a possible problem. Right now these are random and I am having a hard time with Diags. Help Please.
Hal
99 F-250 SD 7.3 PSD 4x4
