upgrade starter
Old Jun 11, 2007 | 09:10 AM
someday's Avatar
someday
upgrade starter
has anyone replaced an old type starter for the permanent magnet type starter found on 92s and up? is it a direct swap?
i would like to change my weak, crappy, heavy starter for the improved design
Old Jun 11, 2007 | 09:55 AM
quicklook2's Avatar
quicklook2
92 thru 96 is still the old type starter.
Old Jun 11, 2007 | 12:53 PM
someday's Avatar
someday
r u sure because my 89 f350 uses the ~16 lbs starter and all the 92 and up starters are about ~8lbs and more compact
Old Jun 11, 2007 | 10:38 PM
someday's Avatar
someday
hopefully i wont damage the flywheel when i try using the newer starter, but i cant believe im the only one to think of this
wish me luck
Old Jun 12, 2007 | 05:37 PM
lostin90s's Avatar
lostin90s
The newer truck use a high torque starter . Hate to say you have the better one . The newer ones have let me down more than all the monsters put together. And Can be rebuilt easily/cheap. My local shop will rebuild old for half price of a high t rebuild. AS for working on your flywheel I don't know look at gears and compare.
Old Jun 19, 2007 | 06:19 PM
someday's Avatar
someday
WOW!!! huge improvement, different sound and starts quicker and easier even after running hard
Old Jun 19, 2007 | 06:52 PM
92F150Flare's Avatar
92F150Flare
Show us a pic or a link of what you bought and used and what year truck did you put it on?
Thanks
Bob
Old Jun 19, 2007 | 07:26 PM
someday's Avatar
someday
essentially this: http://www.fordmuscle.com/archives/2005/08/Alternator/
Old Jun 19, 2007 | 11:17 PM
'88_F-150's Avatar
'88_F-150
i have a 95 f150 with an 84 trans and bell housing and the starter meant for the 95 wont work with the bell housing the bolt spacing is the same but the position of the drive gear is different and it wont engauge the flywheel
ocracokenc
May 9, 2017 09:46 PM
truckguy933
22
Apr 26, 2017 12:45 PM
Ponyboychris
Apr 13, 2016 10:06 PM
ralbach
Jul 18, 2009 08:24 AM
63F100Unibod
Feb 24, 2005 07:38 PM
