Buring B100 In a Powerstroke?
I did a little searching but really did find the answer to a question I have so here goes…<o =""></o>
A guy that lives down the road has started making bio and is using it in his VW TDI for about a year now. He is looking for a little help collecting oil and since I work in the opposite direction I could help and would enjoy learning the process.<o =""></o>
I would even consider selling my gasser and replacing it with a F250 or F350 diesel if I could burn this BD in it.<o =""></o>
Does anyone know if I can use homebrew in a Ford and are there years that work better than others?<o =""></o>
Thanks for any info
Thanks for any info
As long as it is made correctly it will work in any Ford diesel, or any diesel.
I've been making and using bio for 4 years now in all sorts of diesels, including late model Powerstrokes. I've never had any problems. Any diesels older than 1993 MAY need to have the rubber fuel lines replaced. Biodiesel attacks natural rubber. If you have a lot of miles on your truck it may plug your fuel filter, biodiesel is a great solvent! It will clean out your entire fuel system.
I'll never go back to "dino-diesel"!! My trucks love it.......smoother running, way quieter, better milage, and smiling every time I pass a fuel station
If you havent found it yet, try here: http://www.biodieselcommunity.org
This site is a gold mine of info, and also has plans for processors.
fordcouple99
10-09-2008 06:43 PM
jwplunkett
Fifth Wheel & Gooseneck RV Towing
08-21-2008 07:37 PM
