tps ?
Old Jun 10, 2007 | 10:12 PM
bigbadwolfe's Avatar
bigbadwolfe
tps ?
will a tps from a van work for are truck if not the whole pedal just the sensor ? just wondering i am tring to help someone out thanks
Old Jun 11, 2007 | 01:47 PM
bigbadwolfe
anyone ???????
Old Jun 11, 2007 | 02:25 PM
tjbeggs's Avatar
tjbeggs
No Idea BBW. I have tried to get pics of the van unit to check that very thing but nobody has been able to help me. I am guessing you have a van that needs a TPS. If they are different you can check your junk yards and get the right connectors off the vehicle harness.
Old Jun 11, 2007 | 03:16 PM
bigbadwolfe
what i was tring to do is help someone here with a tps issue i can get them from vans but ther are none in the pickups at the junk yard
Old Jun 11, 2007 | 04:15 PM
MPlayer's Avatar
MPlayer
I would think the TPS should work. I think the van pedal assembly is different than the trucks but the TPS should be the same. All it does is vary 5VDC. I had my TPS go out right before Labor day last year and bought a '96 pedal assembly, which they say isn't the right part number for a '95, and it is still working just fine. I don't know why they have different part numbers for '94.5-'95 and '96-'97 but the part numbers on each component of the '96-'97 assembly were exactly the same as the numbers on my '95 assembly. I don't know if the previous owner changed it before me but the '96 worked in my '95.
By the way, Ford wants like $700 for the '95 assembly and $300 for the '96-'97 assembly. Figure that one out.
Hope this helps. If you can find a TPS for a Powerstroke swap it out and see if it works.
Old Jun 11, 2007 | 06:04 PM
Action4478's Avatar
Action4478
Try here,,,...http://http://www.dormanproducts.com...s_Sensors2.pdf
Old Jun 11, 2007 | 06:53 PM
tjbeggs's Avatar
tjbeggs
great link Rick!
