frt/struts
Old Jun 10, 2007 | 07:41 AM
m@m's Avatar
m@m
Question frt/struts
Has anyone replaced thier frt/struts ? I have a f150 04. replaced rears .easy.--------frts/look a little more involved. rears where shot..53000 miles.
Old Jun 10, 2007 | 01:21 PM
MBBFord's Avatar
MBBFord
Actually they aren't struts, they're a form of coil over shocks, but they are a good thing to replace, and they're pretty easy to install.
They have a couple threads about this, I'll try and get some links.
Old Jun 10, 2007 | 01:55 PM
MBBFord's Avatar
MBBFord
https://www.ford-trucks.com/forums/6...=strut+install
This is the one I was looking for. It describes how to do it.
Old Jun 10, 2007 | 02:55 PM
m@m's Avatar
m@m
Thanks for the reply...what is the differance between a strut/coil over??
Old Jun 10, 2007 | 02:59 PM
m@m's Avatar
m@m
Also should I replace the ball jouints??
Old Jun 11, 2007 | 12:05 AM
MBBFord's Avatar
MBBFord
It's hard for me to describe the difference between the two, but a strut is a brace consisting of a bar or rod used to resist longitudinal compression, and a coil over shock is a shock absorber with a spring to help weight, weight distribution and jounce/rebound performance, more than a regular shock would.
I don't see why you would need to replace the ball joints. On the Previous model F150s, the ball joints were a pain in the as$, and always needed to be replaced, but this model seems to be pretty good.
