When I am NOT logged on, the Posting Rules at the bottom of the page has "may not" by each catagory. When I log on they all change to "may" except the one for posting attachments which I guess is my problem. It still says "may not". I don't have the admin. rights to change it. What does the "post attachments" say for everyone else when logged on?
My posting rules says "You may post attachments". However, I'm not certain that posting attachments is equivalent to posting a picture on this forum (i.e. posting attachments is a different process than adding a picture in a reply/post). Depends on how they have it set up.
Posting an attachment won't work for you.
What you can do is hit the "go advanced" button and then click on the "insert image" (the yellow square with the mountain thing) button. Copy and paste your picture's URL or address into the box. You can get the URL by opening the picture in your gallery and then copying from the address bar.
Why not? I used to be able to. All I can do now is post a link. Is there a setting that I need to change?
I went back and double checked my edit options and the block is checked to allow images and attachments but the posting rule still says "may not post attachments" What gives?
