Sponsored by: Auxito
catalytic converters
Old Jun 9, 2007 | 11:50 PM
kjohnson's Avatar
kjohnson
Question catalytic converters
If I take the converters off of my truck, will the check engine light come on?
2002 Ford F-150 XLT 4x4
74,000 miles
Not sure about the 7700lbs.
Old Jun 10, 2007 | 02:23 AM
Dustin1690's Avatar
Dustin1690
Possibly i dont think so this i think applies to the o2 sensors im not sure if they are in the cats but i dont have any cats on my truck it has never shown the check engine light
Old Jun 10, 2007 | 04:56 AM
Joe Finn's Avatar
Joe Finn
Yes, the CEL will come on. There are O2 sensors before and after the CATS.
Old Jun 10, 2007 | 05:39 AM
ncranchero's Avatar
ncranchero
The "after" O2 sensors will be what sets off the light. You can "fix" that with your choice of these:
http://motors.search.ebay.com/?from=...MIL+eliminator
Old Jun 10, 2007 | 10:13 AM
kjohnson's Avatar
kjohnson
How many of the MIL+eliminator will I need if I remove my converters? Thanks for the info.
Old Jun 10, 2007 | 10:29 AM
osteodoc08's Avatar
osteodoc08
Not to rain on your parade, but taking the cats off is illegal. If you don't care, the choice is entirely up to you. It's not like I don't speed every day.....
I'm just making sure you are aware of this. There are always high flow cat options
Old Jun 10, 2007 | 01:50 PM
StephenH's Avatar
StephenH
You will need them for your back two sensors. Leave the front sensors on.
Old Jun 10, 2007 | 06:39 PM
Dustin1690's Avatar
Dustin1690
Weird oh okay iam wrong lol heh well mine has never came on which i find odd
Old Jun 10, 2007 | 10:16 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Good luck getting the truck inspected with no cat converters on it. I'd take them off and weld a straight piece of pipe through them, then weld them back on so it looks like they are functional.
www.o2sensorsimulator.com
Old Jun 11, 2007 | 05:31 AM
ncranchero's Avatar
ncranchero
Did that on my Ranger a couple of years back. Never had an inspection problem!
Old Jun 11, 2007 | 06:05 AM
kjohnson's Avatar
kjohnson
If I weld the piece of pipe through the converts, will I still need the MIL-eliminators?
Old Jun 11, 2007 | 06:12 AM
ncranchero's Avatar
ncranchero
Yes. Welding the pipe through them is in effect the same thing as removing them except they "visually" remain. Fools the inspector. Even after straight piping my Ranger converter my tailpipe readings were in the "PASS" range.
Old Jun 11, 2007 | 07:14 AM
phil6608's Avatar
phil6608
If you leave the o2 sensors in place you may not get a light.
I have talked to people that have not got a light and some do.
I would recommend running 2 high flow cats to replace the 4 cats.And putting the o2s back as close as you can to ware they were.
Then your legal and it will sound great!
Old Jun 11, 2007 | 10:07 AM
ncranchero's Avatar
ncranchero
I am pretty much in agreement, unless your cats are stopped up they're not worth messing with. If they are restricted, straight pipe 'em and put 'em back.
