Sponsored by: Real Truck
New Tires
Old Jun 9, 2007 | 10:13 PM
GKDave's Avatar
GKDave
New Tires
Hi Guys,
I put some Cooper Discoverer ATR's on my '06 F-350, 275-70/18E. The Coopers replaced the stock Conti's. Should I run the Coopers at the recommended tire air pressure per the door sticker or something different. Max air pressure on the Coopers are 80# cold.
Dave
Old Jun 9, 2007 | 10:23 PM
PHWLEE's Avatar
PHWLEE
I would stick with what the door stickers say. Unless you are going to do something specific like going on soft sand or dirt...etc... (need to drop the pressure) the door sticker pressure will be good. keeping it at the optimal pressure will give you the least rolling resistance for everyday driving.
Old Jun 10, 2007 | 11:59 PM
preppypyro's Avatar
preppypyro
I wouldnt run them max pressure. I would run them around 55 psi.
Old Jun 11, 2007 | 12:31 AM
c.f.moore's Avatar
c.f.moore
I run 60-65psi in the fronts, and 55psi in the rears, while running empty. I raise the rears to 80psi when I tow my fifthwheel or when I'm going to haul heavy loads.
Old Jun 11, 2007 | 10:09 AM
redford's Avatar
redford
FTE Leadership Emeritus
Stick with the door sticker pressure unless you go to a different size.
Also, keep an eye on the wear. If you see the tires wearing in the middle, drop the pressure 5 pounds.
