What coolant do you use
Old Jun 9, 2007 | 07:11 PM
chumley's Avatar
chumley
I have a 2007 6.0 PSD and I just discovered that I have experienced a little coolant puking. The only performance mods I have are a turbo back exhaust and a SCT tuner (mild tunes only).
I would like to put more coolant back in the degas bottle as it is low now. I know what coolant is specified in the manual, I just wanted to know what the other 6.0 owners here use/recommend.
Thanks,
Chumley
Old Jun 9, 2007 | 07:18 PM
WishIhada7.3's Avatar
WishIhada7.3
motorcraft gold coolant for a fill up.
Old Jun 9, 2007 | 11:20 PM
Powerstroke_wannabe's Avatar
Powerstroke_wannabe
What Wish said. Also, keep your coolant at the min level.
Old Jun 10, 2007 | 03:31 PM
TIMM BALDAUF's Avatar
TIMM BALDAUF
Drain,flush & refill with EVANScooling.com great for coolant pucking problems as long as there are no other problems.
Old Jun 10, 2007 | 03:38 PM
UGA33's Avatar
UGA33
Make sure when full it is at the min level like said above. That is the new max level. Another vote for motorcraft gold
Old Jun 10, 2007 | 06:13 PM
BGMSPD's Avatar
BGMSPD
depending how low it is you can always add a little water. if your adding water make sure the truck is cool when you add water. you don't want to add cold water to a hot system. i've never put a lot of water but after my last flush at the dealer i came home and it was a little low. took it back and they put warm water in since the truck was warm. so as i understand it, you can add a little water if low. but i would assume that you should still have a mix of water and gold coolant.
if i'm wrong someone please let me know.
Old Jun 10, 2007 | 06:16 PM
Beachbumcook's Avatar
Beachbumcook
Got Diesel?
Just becuase you have "mild tunes" from SCT does not mean anyhting. It depends on how they were written and by whom. I would call Long Island Perforance Diesel and talk with them (talking is free).
I would go back to stock and run for awhile and see if the puking stops. Puking is more common with trucks with tuners... so I suspect this maybe the cause depending on the "tune".
As far as coolant... fill to "MIN" and use Motorcraft Premium Gold (from dealer).
Good luck,
Old Jun 10, 2007 | 09:59 PM
garcherd's Avatar
garcherd
50/50 mix of Motorcraft Gold & distilled water is what Ford recommends and do not fill to the MAX line.
D8chumley
2009 - 2014 F150
Jun 6, 2010 07:27 PM
D8chumley
Sep 3, 2008 09:29 PM
chumley
All Things Towing
Feb 6, 2008 11:34 PM
D8chumley
Jun 14, 2007 08:04 PM
chumley
S. California Chapter
Jan 16, 2007 08:40 AM
