Trans help---ASAP
Old Jun 9, 2007 | 05:28 PM
Ford79's Avatar
Ford79
Trans help---ASAP
I installed the BTS VB today and all went well. I got the bottom end all buttoned up and went up top to dump in the fluid. First 1/4 quart ended up on the ground, WTF.
Turns out, the dipstick tube is broke at the tab that is bolted to the trans.
I would like to know how much fluid is needed to get it close because of the way I have to fill it. I took a piece of 5/16" hose and snaked it down the tube past the bad spot and now it takes about 3 minutes for a quart to go in. I will be ordering a new dipstick tube Monday, which looks like another enjoyable job to install.
Old Jun 9, 2007 | 06:07 PM
Uzumati's Avatar
Uzumati
If all you did was dump what was in the pan 6 qts should get you close enough till you get her fixed.
Old Jun 9, 2007 | 08:21 PM
mustang_gt_350's Avatar
mustang_gt_350
you could always measure what you drained from it if you still have it and didn't spill much.
Old Jun 9, 2007 | 08:32 PM
sgrol's Avatar
sgrol
I feel your pain. When I installed my 4", I broke the chicken S welds that hold the tube to the bracket (which is bolted to Head, not trans). I would add tranny fluid and end up with a puddle on the floor (not as bad as yours). Couple of weeks ago, while doing turbo work, I pulled the tube off and welded it up.
