Overdrive
Old Jun 9, 2007 | 03:41 PM
mtntop1's Avatar
mtntop1
Overdrive
What would cause the overdrive to shift in and out while going a steady 50 mph or more on a level road,no climbing.It only happens once in a while.
Old Jun 9, 2007 | 03:44 PM
00bucker's Avatar
00bucker
Torque Converter
Old Jun 9, 2007 | 04:45 PM
mtntop1's Avatar
mtntop1
Can you be more specific about the torque converter.
Old Jun 9, 2007 | 05:16 PM
bustedflush's Avatar
bustedflush
mine did that every once in a while. Turned out to be the OD switch on the dash. the switch was worn out and when I hit a bump or vibration would cause it to turn on and off. Scared the hell outta me - turned out to be a $4 fix.
Old Jun 10, 2007 | 07:34 PM
00bucker's Avatar
00bucker
First of all how many miles do you have on the transmission, and how long has it been since you changed the fluid. Also it will help to know the year of the truck. When it shifts out does it appear to do it for no reason or does it do it because it is starting to baug?
Old Jun 10, 2007 | 09:20 PM
mtntop1's Avatar
mtntop1
The truck is a 1995 F-150 with 103,000 miles on it.I change the fluid and filter every 20,000 miles.It shifts out for no reason but only occasionally.I can be going a steady 50 to 60 mph when it happens.Like I said it is not a constant thing.
Old Jun 11, 2007 | 07:44 PM
00bucker's Avatar
00bucker
Yea im with "bustedflush", i would start checking switches and pull codes and see if you get anywhere.
Bigtony4
2004 - 2008 F150
18
Jun 22, 2008 03:13 PM
searay280
32
Jun 17, 2008 03:09 PM
jonnyboy78023
18
Mar 24, 2008 11:00 PM
Leader
Mar 10, 2007 08:57 AM
buzzard
Apr 20, 2002 01:01 PM
