Positraction
Old Jun 8, 2007 | 07:22 PM
zeaga's Avatar
zeaga
Question Positraction
Hello Ladies and gents,
I am about to change gear ratio from 3.55 to 4.10. I have an open differential. I was wondering if it's possible to change from an open to positraction differential? I have a 1998 F150 4.6l V8 4x4.
Thanks.
Old Jun 8, 2007 | 07:33 PM
75F350's Avatar
75F350
"positraction" was a term G.M. used, Ford uses "Limited slip", and yes it is possible to install a limited slip carrier into your truck.
I am not sure of the break for the 8.8" rear axle, but you may end up changing carriers anyway. If you want a limited slip, now is the time to do it.
There are clutch type, similar to the factory type and gear type units are also available, so you have a couple of choices.
Old Jun 8, 2007 | 09:34 PM
zeaga's Avatar
zeaga
What's the pros and cons between clutch and gear limited-slip? And which brand I should buy?
Thanks.
Old Jun 8, 2007 | 10:18 PM
andym's Avatar
andym
That depends entirely on what you use the truck for. Are you running a lift and oversize tires or just want a little more traction in the winter?
There is no carrier break for the 8.8" or the 9.75" axle.
You know you will have to re-gear front and back, right?
96Aerostar
Aerostar
Jun 8, 2014 11:05 AM
rjbuningsr
Apr 7, 2014 08:05 PM
bob1987f
Jan 24, 2005 02:02 PM
snagmaster86
Nov 2, 2004 09:39 AM
Dusty McGuire
Aug 5, 1999 07:52 PM
