Posi rear end?
Old Oct 31, 2004 | 04:52 PM
snagmaster86's Avatar
snagmaster86
Posi rear end?
I have a 79 F-250 4x4 and i think my rear differential is a Dana60 but I am not positive. Any ideas if that is right? If it is a Dana 60, is it a posi-traction differential? If not what is the best posi differential to replace it with?
Thanks,
Dan
Old Nov 1, 2004 | 06:51 AM
RTM's Avatar
RTM
Just because you have a dana 60 doesn't mean you have a posi set up. Jack one side up of the rear axle and put the truck in nuetral and see if you can rotate the tire that is off the ground. If you can rotate it then you do not have a posi set up. You could still have a very worn posi so it would be wise to check the door tag and look up the axle code.
Old Nov 1, 2004 | 10:38 AM
snagmaster86
thanks. I'll check it out.
Old Nov 2, 2004 | 01:16 AM
peppy's Avatar
peppy
Also you can jack both wheels of the ground.
Tires go opposite directions..open diff.
Same direction.....limited slip.
Old Nov 2, 2004 | 09:39 AM
snagmaster86
sounds simple enough.....and jimmy buffett has my vote
obx 79 shortbed
Aug 30, 2014 10:20 AM
Cdn4X4
Ford Truck Parts for Sale
Mar 24, 2014 09:50 PM
alans77crew
Oct 19, 2013 09:05 AM
GMCPic
Oil & Lubrication
May 26, 2013 01:02 PM
Triple Threat
Dec 19, 2004 12:13 PM
