Gauges are here, connection locations?
1- Pyro: no brainer, drill tap and mount thermocouple in Drivers side manifold
2- Fuel pressure: also a no brainer, remove valve on side of FPR and adapt it to fit the line. Put in an isolator. Q: will this gauge go bad quickly if I leave it connected all the time due to spikes in pressure? If so is it safe or recommended to put a valve in line so I can check it when I need to and not leave it pressurized all the time.
3- Boost: I got that one too, "T" into map line. I know there is a better place to drill and mount it but I can't remember where on the turbo housing to drill.
4- Back pressure, I believe I got that one also, Remove back pressure sensor and get some fittings to make a "T" and put the original sensor and the aftermarket line back on. Also run a metal line from it to dissapate heat before it gets to the plastic line.
5- Oil pressure, I don't have this one, I think on or near oil filter housing but not sure. I definately need help with this one.
I numbered these to make it easier to reply back. Thanx in advance guys.
#2, Not 100% positive on this but I believe that the isolator with dampen the spikes and your gauge will be O.K. But to be sure, call the manufacturer and ask them.
#3, correct, or drill and tap into the intake "Y" pipe.
#4, correct, make sure you remove the back pressure senor tube and clean it our really well brake cleaner and a wire.
#5 I usually put a "T" into the top of the HPOP reservoir and then put the factory sender and new sender in at this location. Off of the top of my head I cannot remember which plug it is at the location at the oil filter. I'll check and get back with you.
#4 the whole tube needs to be removed? Where does it reconnect? it goes down and disappears. I haven't looked to see where it goes yet.
#5- I guess I will try the top of the HPOP but I didn't think it was the right pressure but since the factory unit is there it shouldn't matter. Also if I wanted could I just leave the factory unit off or would that throw a code and possibly put it in limp mode?
Thanx plowhand
Neal, #3, I tap into the left (drivers) side of the "Y", Just above and infront of the leg going to the intake. Location really does not matter as the entire intake system is pressurized. I have seen them put in all over the "Y" pipe.
#4, the bottom of the back pressure sensor tube goes into the front of the right (passengers) side exhaust manifold.
#5, I don't know if it will throw a code, but your factory gauge will not work. The engine oil pump pressurizes the HPOP reservoir to keep it full. I use a T, a short nipple, and two street L's. Then both sensors are pointing back towards the cab.
Hope this helps.
Hope this helps.
#4 what seals it? In otherwords what will I have to get to reinstall. Maybe it is just pressed with a fork and bolt, not sure but I can check it out myself.
#5 sounds like the best way thanx plowhand.
#4, it has a nut fitting on the bottom of the tube, if I remember correctly.
casey, cleaner install, less tubing to run and get in the way when doing other work. That's my reason.
http://www.dieselmanor.com/installsheets.asp
Nice pictures too.
