fords aren't classified as big blocks/small blocks,their engines are classified by families/groups,although it is common to hear the 351w/302/289 called "small blocks" and the 400/460/360/390 called "big blocks". big block/small block is gm terminology.
Ford has engine families. Big block and Small block are old Chevy terms that unfortunately get bandied about and misapplied to Ford engines.
Note- the 351W, 351C, 351M and 352 all have the same 4" bore and 3.5" stroke making them all the same displacement. They just have different designations. Some sources do list the 352 as having a 4.002" bore tho but most show 4.000".
BTW- many of those old engine books were written by Chevy guys...
I went thru engine specs for many brands of engines, deck height was not a good indicator for the old big/small block terms. A more accurate indicator was bore spacing, about 4-9/16" was near the dividing line if I remember right and seemed to work. -If you must use Chebby terminology.
When I hear "Ford big block" I instantly don't take the guy serious.
You need to be more specific to sound like you know what you are talking about. What not to say:
"My buddies cousins neighbor has a Ford big block that'll blow the doors off anything"
To me BB is chevy talk.
Agreed, bore spacing is the factor....and even though big and small are Chevy terms, it's been accepted for Ford as well as evidenced by million's (and many others')book(s).
Agreed.
The next most popular, statement of total ignorance is:
"I've got to get me a STALL CONVERTER installed soon."
Ummmm. Hey, Nimrod, ALL torque converters have stall.
