looking for suggestions on mods
Old Jun 8, 2007 | 02:14 AM
axgarcia's Avatar
axgarcia
I was looking to put a lift kit and wheels on my 04 f150 fx4. Im just not to sure what looks good on these trucks. Any suggestions: type of lift rims and tires. Im also wanting to use some kind of tuner? i just dont have a clue as to what is better superchips, edge, etc. help me out guys. heck i wouldnt mind checking out you trucks if you got pics of your truck.
Old Jun 8, 2007 | 07:57 AM
Rough Country's Avatar
Rough Country
FTE Sponsor
Rough Country offers a leveling spacer for $ 129 which lifts your truck 2.5 inches and we have just got a 6 inch prototype kit on a truck as well.
Old Jun 8, 2007 | 08:26 AM
desertford's Avatar
desertford
check out my gallery 6" fab tech lift 17" moto metal 951 rims 35' bfgs I am very happy with it drives great
Old Jun 8, 2007 | 08:29 AM
Blackstock's Avatar
Blackstock
Former Vendor
The leveling kits gives you a 2.5" lift and great bang for the buck. Are you prepared to go from 2.5 to 6" for roughly $2000 more? You can fit 35's and I would reccommend the Edge Evolution. The pod looks excellent, very good support from edge and it allows you to control numerous functions including changing the tire size. As for rims, decide if you want the tire and rim sticking outside the wheel well and if you are traveling on gravel you will need flares to protect the sides and then they should be painted etc etc. The leveling kit, 17x33 Mickey Thompson's and the flares make a great value combination. Check out our site and compare the Mojave (level kit), FX6 (6 inch) and Baja (level kit, factory rims and no flares)
Old Jun 11, 2007 | 02:03 PM
surelly09's Avatar
surelly09
Those are for installed kits... do you do anything on kits not installed?
Old Jun 11, 2007 | 04:13 PM
Blackstock's Avatar
Blackstock
Former Vendor
Not sure who you are referring to, but these are our online parts only prices in Canadian funds http://www.f150sale.com/accessories.html
Old Jun 11, 2007 | 05:02 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
Leveling kit: Autosprings 2.5" lets you fit certain 35" tires
Lift Kit: RIZE 8" kit allows up to a 38" tire. you can fit 40" tires with the 8" and stacking a 2.5" AS ontop in the front and a 3" add-a-leaf in the rear
RIMS: Moto Metal 950 series 20x10 rims
Tires: Toyo Open Country M/T 35x12.5x20
a pretty good amount of people have the rim/tire combo and use the 2.5" spacer. The F-150 looks pretty darn good IMO with that combo. The 8" lift and 38" tires looks even better, but it's hard on the IFS front end.
EDGE Evolution for everyday performance, and a SCT X-Calibrator II for the max performance. Alot of guys swear by Bama Chips tuning.
Old Jun 11, 2007 | 06:56 PM
ech0sh4y's Avatar
ech0sh4y
with the 2.5 you can stuff 35's under our trucks? Or is that only FX4 guys? What about 2 leveling how big can we go then? minus the 305/65/18 that are goldy expensive
Old Jun 12, 2007 | 11:01 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
any 4x4 will fit 35" tires with a 2.5" leveling kit. the size to prevent most rubbing issues is 35x12.5x20...I haven't seen them on a 18 or 17 rim yet. You will have to trim the fender skirt, but most people report that they only rub on full turn
I'd stick with a 34" or smaller tire if you're getting the 2". You can probably fit the 35" also, but there is more rubbing risk
FYI: the FX4 is the same as the 4x4, it just has better shocks, but they sit the same hieght. The 4x2 has different shocks, so it's front end sit 1" lower than the 4x4
Old Jun 12, 2007 | 04:56 PM
ech0sh4y's Avatar
ech0sh4y
The only difference between the fx4 and 4x4 mechanically is the shocks?
Old Jun 12, 2007 | 08:37 PM
VFR_Man's Avatar
VFR_Man
Unless you add them (option) to the regular 4x4, the FX4 also comes with the skid plates standard.
Old Jun 12, 2007 | 10:20 PM
MBBFord's Avatar
MBBFord
Like VFM_Man said, the shocks are the same, they only put stickers on them, and FX4s come with skid plates.
As for mods, depending on use, and how much money could be used, but either X-Calibrator II or EDGE Evolution or Bama Chips.
A volant intake
Dual exhaust with a DIDO Magnaflow, and remove the 2 rear cats.
A 2.5" Leveling kit if money is a problem(If you can't justify spending $2K on a 6" lift).
Some 17" wheels! 20s cost to much, and tire prices are unbelieveable for 20s, but for 17s they're ok.
A 34 or 35" super swamper(or tire of your choice, but I love swampers.
Here's a few pics on a 04 w/ leveling kit and new rubber:
https://www.ford-trucks.com/user_gal...&albumid=26793
Old Jun 12, 2007 | 10:32 PM
SDTruckMan's Avatar
SDTruckMan
Matt dont think I could do all that mud to my truck so soon, but it does look like it was fun..
Old Jun 13, 2007 | 06:39 PM
ech0sh4y's Avatar
ech0sh4y
If the lariat comes with 18" wheels stock can you downsize to 17" wheels? tires are cheaper for 17's than my 18s
Old Jun 17, 2007 | 11:28 AM
bad_chopper's Avatar
bad_chopper
i put 33 12.5 18s on my fx4 i use the evalution edge wich was about 440 an afe stage 2 cold air intake and single in dual out borla exhaust i baught the truck used so i was able to take my tuner and my tires with me of the o6stx i traded in.
edge evelution 440
afe cold air 295
toyo mud terains 1250
borla exhaust already on truck when i baught it.
all together i think i get around 13mpg every day driving.
i would like to get a full throttle lift
some 38s
and run 4.56s i think i t should do fine. but with the toyos i have i think i have about two years to save up lol for the lift before the tires wear out.
