OK, this is an embarrassing newbie question, but where is the fuse panel located on a 98 F250 LD? I believe it's under the driver's dash, but I don't SEE it. I can't seem to get running lights to work on my horse trailer, and while I'm checking grounding, etc. I'd like to check the fuse. Is there a fuse diagram/listing on-line somewhere? It didn't come with the manual (used)
Thanks
Reason: changed the truck year from 89 to 98 :)
I checked out his profile and recent posts...he has a 98 F250 LD. Must have just put the numbers opposite. I fixed his post. This is the correct forum.
