body swap
Old Jun 7, 2007 | 04:21 PM
arockyway2go's Avatar
arockyway2go
Unhappy body swap
can anyone tell me if 86 front sheet metal will fit a 88 cab?I have a rolled 88 f-350 7.3 5spd 4x4,and a new mexico 86 f-150 with a blown 300,yes blown i didn't believe it myself till i pulled the pan.Basically what i am asking is can i use the front sheet metal and bed or do i have to use the cab also?
Old Jun 7, 2007 | 09:32 PM
surewhynot's Avatar
surewhynot
The cabs are similar. The front clip will bolt up. You will need to use the 86 core support and inner fenderwells too. The bed will also fit.
Old Jun 8, 2007 | 11:21 AM
lostin90s's Avatar
lostin90s
Will fit .You will/May have to cut center section rad support to use the big rad in the 86 sheet matal Good luck on swap
