Dp tuner
Old Jun 7, 2007 | 02:55 PM
redneckboy's Avatar
redneckboy
Dp tuner
Clumsy me hit it and broke one of the wires its one of the two black ones and it doesnt go with all the others in to the clip any one know where it goes was it possibly a ground. it seems a little thicker then the other black one.
Old Jun 7, 2007 | 04:14 PM
Redonthehead's Avatar
Redonthehead
The wiring harness I got with my DP had a broken wire - actually near a solder joint. Cut the main black shrink wrap off and I think you will see the grounding wire (it looks thicker as it has its own shrink wrap) which is actually outside the cluster of inner wires is/was soldered to the short little red wire that came out the backside of the connection box.
edit - of course you may just want to ask Jody for a new one. But if you solder it back together, make sure you do it on low power so you don't overheat the insulation on the red wire.
Old Jun 7, 2007 | 04:24 PM
redneckboy's Avatar
redneckboy
I was in a parking lot no tools so I had to go home and get them and take it out and it is that wire. Its so short I dont think there is anyway i can soder it. I was going to send it back and get more put it on it. Guess now is the time. Thanks for the quick reply. I appreciate it.
jasonkpowell
Jul 3, 2014 10:08 PM
xc4jokestomper
36
Feb 12, 2012 02:27 PM
jake00
Feb 10, 2011 10:01 AM
ReForder
2004 - 2008 F150
Jan 4, 2006 08:25 PM
DaParm
24
Oct 13, 2004 02:12 PM
