Throttle cable for a 66
Old Jun 7, 2007 | 10:28 AM
1996pwrstrk's Avatar
1996pwrstrk
My dad's thottle cable broke on his 66 the other day when he was pulling out into traffic luckly he was able to get out of the way before some one hit him. He's got some kind of arrangement on there that just doesn't look very nice I would like to put something better on there for him. The truck is totaly restored with the exception of the drive train he's running a 302 with a carb I know a lot of you guys run this combo and wanted to know what you are using.
Old Jun 7, 2007 | 11:01 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
What is the exact length of the cable?
Old Jun 7, 2007 | 11:15 AM
1996pwrstrk
I will have to get it for you . I am at my hse and dad's not home I will try to get tomorrow.
Old Jun 7, 2007 | 11:36 AM
airharley's Avatar
airharley
You can use an aftermarket cable as well with minimal modifications to the pedal and carb. Sometimes they're less expensive and sitting on the shelf at most part stores. I am running a Lokar knock off that looks and works really well.
Old Jun 7, 2007 | 05:03 PM
jowilker's Avatar
jowilker
I know that Rick at Carolina Classics carries them and am pretty sure others do too.
John
Old Jun 7, 2007 | 07:53 PM
Customcab's Avatar
Customcab
I just used a 66 model v-8 cable from the donor truck with a (76) 302 I installed acouple years ago. I also had to change my gas pedal from a 65 to a 66 model to allow it to clip in; you shoudn't have that problem with your dad's 66, Also I do have a loop in the cable behind the carb on my Slick. Check my gallery & on the right rear side of my air breather you'll see the loop of my cable.
Mitch
Last edited by Customcab; Jun 7, 2007 at 07:55 PM. Reason: add info to clarifiy my reply
Old Jun 8, 2007 | 04:56 AM
daveengelson's Avatar
daveengelson
65 F100 w/ 302, modified firewall and went w/ later model pedal and direct linkage.
dave
bainenbecky
Nov 12, 2014 07:35 AM
blue66tang95f150
22
Jan 25, 2010 10:55 AM
Country705
1997 - 2003 F150
Jun 30, 2008 03:34 PM
oldtrapper
Jul 9, 2005 01:18 AM
66MercMan
Mar 7, 2005 09:56 AM
