One MORE question! Oil Pan
Old Jun 7, 2007 | 10:26 AM
ejolliffe's Avatar
ejolliffe
Anyone know the torque specs for the oil pan gasket bolts? Also, you start from the middle and work out right? Also, does it matter which side you start from?
Old Jun 7, 2007 | 12:43 PM
bronco521's Avatar
bronco521
i snug one down in the middle and go over to the other side in the middle and work my way out going side to side.i just snug em down until they are all about the same then start over and take them down tight.i use the 1 pc gasket for the later 90's 460's and they have inserts for the bolts so you cant crush the gasket from over tightening.you do have to pick the inserts out of the gasket on the corner bolts that are a 5/16" and the gasket only has 1/4" inserts .
Old Jun 7, 2007 | 02:15 PM
airharley's Avatar
airharley
15 ft/lbs or 180 in/lbs from all of the referance material I have. To convert in/lbs to ft/lbs divide by 12 or multiple ft/lbs by 12 to get in/lbs.
caleballen95
May 21, 2014 05:47 PM
6.9 BLUES
Apr 2, 2014 12:21 AM
robjs111
1997 - 2003 F150
Apr 1, 2011 08:19 PM
firemanbird
Aug 20, 2007 10:47 AM
mattlundb911
Oct 9, 2005 07:25 PM
