Cam Question
Old Jun 7, 2007 | 10:21 AM
ejolliffe's Avatar
ejolliffe
Smile Cam Question
Maybe a dumb question, but what is a 'mild cam' exactly. The truck I bought had a rebuilt 460 and a mild cam was installed. What is it exactly and what are the benefits to using it, performance wise anyways. Thanks for the input.
Old Jun 7, 2007 | 02:18 PM
airharley's Avatar
airharley
A mild cam is one that has slightly larger lift with the same duration. There are some that reference an RV cam as well. Thats not much more then stock but plays around with the time when the valve opens or how long.
Old Jun 7, 2007 | 02:19 PM
ejolliffe's Avatar
ejolliffe
Thank you! So it is better than a stock cam in terms of lift. Does this add horsepower?
Old Jun 7, 2007 | 02:28 PM
airharley's Avatar
airharley
Any cam that is larger then stock will add some HP and TQ but don't expect to run 10 sec passes on the strip. Unless your driving a tube chassis or a really really light vehicle.
Old Jun 7, 2007 | 02:29 PM
ejolliffe's Avatar
ejolliffe
No, one of the heaviest! '78 F150 longbed with 460CID in it! I am just trying to get a better understanding of my truck, I guess!
Old Jun 7, 2007 | 02:36 PM
kermmydog's Avatar
kermmydog
With a cam: The greater lift increases torque. Longer Duration equals more HP. RV so-called cams increase the lift for torque reasons. There is a fine line as to what cam to use. The cam needs to work with the rest of the engine to give you MAX PERFORMANCE. There are many variables in figuring for the right cam.
Old Jun 7, 2007 | 02:38 PM
airharley's Avatar
airharley
Check out the "how it works" website. They have a lot of basic info on cams that might be helpful for what you are looking for. Not to mention pretty much anything else car related.
