Machine work for heads?
Old Jun 7, 2007 | 08:20 AM
wvbogger's Avatar
wvbogger
I have just completed a full port and polish on a set of D3VE heads. I will be running 2.19/1.76 valves. The following is what I think I need done on the heads. Clean, magnaflux, square it up, bronze valve guides, cut guides for valve seals, cut seats for larger valves and do multi-angle valve job, and machine for screw in studs. I will have about 11:1 compression and be running leaded race fuel. The motor is going to be used for mud racing. Did I miss anything for the machine shop? I was told not to spend the money for hardened exhaust valve seats do to running leaded fuel. Is this true? I will be running stainless steel valves.
THANKS
Old Jun 7, 2007 | 09:22 AM
darrin1999's Avatar
darrin1999
your valve job would last a lot longer with the hardened seats, and it would make the heads more durable... so id throw in the extra to put them in. being youre cutting for bigger valves theyre pretty much necessary. part of what youre cutting away is the factory induction hardened part, so with everything already done to them, dont you think it would be better to have them just for the peace of mind?
Old Jun 7, 2007 | 02:41 PM
kermmydog's Avatar
kermmydog
I have been warned here, that the factory seats aren't real hard once you grind on them. That replacing them is money well spent.
Old Jun 7, 2007 | 03:15 PM
monsterbaby's Avatar
monsterbaby
also it's not that much money to have hardened seats installed on the exhaust side (don't bother with the intake they aren't the problem) also take your guide plates in with the heads so they can mill the pedestals down the proper amount, I have seen guys machine them for the studs and not take off the extra for the guideplates and bottom out the rockers when trying to get proper valve geometry. your machinest may just take a certian amount off anyway but me and the guy that does my machine work prefer to cut them the amount of the thickness of the guideplates
also if you have your valve springs now is a good time to check to make sure the spring seats are large enough for them and have them cut if neccesary.
Old Jun 7, 2007 | 03:50 PM
airharley's Avatar
airharley
I would also suggest having the air injection ports on the ends of the heads threaded for screw in plugs. Not a huge deal but it prevents mysterious exhaust leaks down the road.
dustinlauricha
Mar 4, 2012 12:48 AM
brit_wheels_fan
Feb 4, 2010 11:19 PM
effie_man
Jan 4, 2009 10:11 PM
gungho351
21
Jan 2, 2009 11:11 AM
C-Leigh Racing
Nov 14, 2008 11:01 AM
