Fuel Filter Top Removal
Old Jun 6, 2007 | 04:01 PM
FARM69's Avatar
FARM69
Tried to change my fuel filter out yesterday morning as it's long overdue to be replaced. However, I couldn't get the cap to move at all. I'm wondering if the heat from my intake spyder has somehow fused the gasket the the plastic and metal pieces? Any ideas on how to get the cap off without breaking the plastic?
Old Jun 6, 2007 | 04:50 PM
plowhand's Avatar
plowhand
Playing in the Dirt
Try an oil filter wrench, the band type. I have used it to loosen stuck fuel filter housing caps before. I think some of the O-rings swell more than others and this causes the sticking caps.
Old Jun 6, 2007 | 06:18 PM
FARM69's Avatar
FARM69
I'll have to give that a try tonight. It may be difficult to get the band on the cap portion of the filter though.
Old Jun 6, 2007 | 06:22 PM
Cuda_jim's Avatar
Cuda_jim
They can be a bear to remove. Use a screw driver or another piece of metal that will span across the top and provide some leverage. You will need to remove the decorative cover to do this.
Old Jun 6, 2007 | 06:28 PM
FARM69's Avatar
FARM69
yeah, i've already done that. Used one of my gaint screwdrivers to get at it. Problem is I have intercooler pipes and the intake spyder in the way making things tighter than normal.
Old Jun 6, 2007 | 06:49 PM
plowhand's Avatar
plowhand
Playing in the Dirt
Try shocking it with a hammer with the screw driver across the top and then tapping the screw driver to loosen.
Old Jun 6, 2007 | 07:45 PM
Aireeek's Avatar
Aireeek
MBPR Power Tube
Hey Guys. Newbie here to the forum and to Diesel ownership. I want to start my Mods with a intake and exhaust system. I was wondering if anyone had any input on the Power Tube being offered by MBPR? Reek
Old Jun 6, 2007 | 07:47 PM
Aireeek's Avatar
Aireeek
opps
Sorry, Wrong place.
Old Jun 7, 2007 | 01:07 AM
Jacksfirstdiesel's Avatar
Jacksfirstdiesel
They seem also to be tighter under pressure. If you bleed it to a drain pan first and tap-tap-tap it it might help
Old Jun 7, 2007 | 07:56 AM
FARM69's Avatar
FARM69
I finally got it removed late yesterday afternoon with the help of a hammer. Thanks for the help gentlemen.
Old Jun 7, 2007 | 08:06 AM
plowhand's Avatar
plowhand
Playing in the Dirt
Glad you got it off.
