new seals.
Old Jun 6, 2007 | 01:57 PM
Saber123316's Avatar
Saber123316
new seals.
How much does the average 302 rebuild cost for you guys. just because I have oil hitting my hot exhaust and I want to rebuild the engine. so new seals and rings are the call of the day. what would I be looking for average cost.
Old Jun 6, 2007 | 02:12 PM
subford's Avatar
subford
Sounds like you need to replace the valve cover gaskets or tighten the valve covers.
Old Jun 6, 2007 | 02:36 PM
andym's Avatar
andym
Why would you want to spend the money rebuilding an engine because it leaks a little oil? Wouldn't it be cheaper and smarter to just fix the oil leak?
It's your money though...
Old Jun 6, 2007 | 05:50 PM
Saber123316
thats what i mean I wanna fix the oil leak but still maintain reliability. and the only way i know how to do this is old seals should be replaced.
Old Jun 6, 2007 | 06:19 PM
andym's Avatar
andym
The terminology you're using is confusing, in that case.
You first have to find where the leak is coming from. If it's leaking onto your exhaust, a good bet is the valve cover gaskets.
Old Jun 6, 2007 | 06:45 PM
baffledinpa's Avatar
baffledinpa
Everyone is right on this.
You can go to your local Napa, PepBoys, Autozone and pick up a set of valve cover gaskets for anywhere from 10 bucks to as much as 32 bucks.
Depending on what type you get or want.
I would replace the valve cover gaskets first and then see if you have any other leaks.
If you are having issues with smoking and burning, THEN you might go look at rings and seals.
If you are burning any oil, I would look at a redoing your heads and seeing if the valve stem seals and valve guides might be worn out.
Til then, Save your money if you don't need to go thru an fresh rebuild.
Old Jun 6, 2007 | 07:23 PM
Saber123316
also i am losing coolant and i cannot figure out where it is going. no leaks in resevoir or rad. or on hoses or lines. maybe its the rad cap. but I cannot find it anywhere.
this old truck has got lots of charm in it.
Old Jun 6, 2007 | 07:31 PM
lostin90s's Avatar
lostin90s
Get the good valve cover gaskets .
And yes the rad cap is ussually the problem . You will have to Burp system several time to get all air out. But this doesn't always work as I have no leaks and have put several caps on and still goes down little.
GOOD LUCK LOST
Old Jun 6, 2007 | 09:45 PM
andym's Avatar
andym
You can have your cooling system pressure tested at a radiator shop as well. This will tell you if it's leaking and possibly where.
