Tire size
Old Jul 16, 2007 | 09:30 AM
HKusp's Avatar
HKusp
They fit in the same housing. Just more teeth. It just multiplies the engines torque better. You lose a little when going with bigger tires.
Old Jul 16, 2007 | 08:38 PM
alan hodges's Avatar
alan hodges
As far as the gearing goes I'm sure you can go to the 5s and maybe into the 6s. But trying to find some one who makes them may be the thing. I would think you would be running 48 to 52 inch tall tires to need that type of gearing. The stock axle housing will handle the gears.
Old Jul 17, 2007 | 04:00 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
No i believe that to change the gear ratio, its all in the pinion size. A smaller pinion has to rotate more to make the ring gear spin over once. So as you make the pinion smaller, you have to make the ring gear wider, to make up the difference to have correct gear lash.
