Loweriiing
Old Jun 6, 2007 | 12:18 AM
jake11's Avatar
jake11
Loweriiing
Is it possible to mount the leaf springs upside down and bolt the rearend
on? Notch the wheelwells out for clearance.
Old Jun 6, 2007 | 12:33 AM
Project71's Avatar
Project71
I dont think that the springs will function upside down. the arch is then going the wrong way and you wont really have any rear suspension. I would just do a spring under conversion, if you are trying to do it yourself. That way you still have suspension in the rear, you just have the springs going under the axle instead of over it. Just my $.02 worth.
Old Jun 6, 2007 | 12:45 AM
1fastcavi's Avatar
1fastcavi
i agree. it would be useless to do it that way, just do the spring under conversion.
Old Jun 6, 2007 | 12:51 AM
averagef250's Avatar
averagef250
Yes, of coarse you can flip your springs. Don't forget to check your pinion angle though. If it's off more than 90 degrees it's best to flip your rear axle upside down as well. Don't forget to switch your brake backing plates when you do this, otherwise your E-brake cables won't reach.
Old Jun 6, 2007 | 08:30 AM
TigerDan's Avatar
TigerDan
Funny...
What we used to do a lot when racing was to disassemble the leaf springs and flip just the main leaf (this was on a passenger car so it was already undersprung, and we wanted to stay away from lowering blocks as much as possible.)
This was a bit of a pain to do and since it put the leaves in conflicting arcs, was pretty touchy to assemble, very interesting when one would slip before you could get them bolted back together. I don't really recommend trying it...
It had the effect of flattening the spring and reducing the spring rate. But since you have a truck which is oversprung (spring sits over the axle) I'd do the spring under conversion mentioned above. Much simpler and will get you a quick and easy (relatively easy) 4 inches or so of drop.
Old Jun 6, 2007 | 09:27 AM
73FOMO's Avatar
73FOMO
Why would you want to do that...just flip the axle for 5" of drop, then you could add lowering shackles and hangers for another 4" if needed....that would be pretty low. Lower than that I would go to a 4 link with airbags....of course you will have to c-notch your frame for suspension travel. The challenge will be to get the front as low as the back.
Old Jun 7, 2007 | 10:00 AM
lucky no. 7's Avatar
lucky no. 7
i sure dont understand what you sayin here, like an earlier post said, springs are arched for a reason, as they are compressed they flatten out and become longer center to center meausured at teh spring eyes, hence the reason for a shackle that moves basically in a front to rear motion as the compresss and rebound, yes it would be possible i dont doubt it, but it'll be like ridin in a mexican rice wagon
Old Jun 7, 2007 | 07:14 PM
TigerDan's Avatar
TigerDan
I believe that post was meant to be tongue-in-cheek...
Old Jun 7, 2007 | 07:55 PM
wizzard351's Avatar
wizzard351
if ya flip the axle upside down it would go backwards in drive and forwards in reverse
Old Jun 8, 2007 | 09:08 AM
73FOMO's Avatar
73FOMO
I would just leave the springs as designed and put the axle on top of the spring instead on the bottom of they spring...will lower like 4-5". forget flipping the springs and everything else.
Old Jun 8, 2007 | 02:34 PM
u150md's Avatar
u150md
what about the front
Old Jun 8, 2007 | 09:39 PM
jake11's Avatar
jake11
What if I flip the frame instead. Redo the cab and bed mounts.
Old Jun 8, 2007 | 09:42 PM
1fastcavi's Avatar
1fastcavi
its a truck for gods sake.. leave it like that, i know u want it to look good. but dang, if u want it that low put some bags on it, be a heck of alot easier in my eyes.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
