19-92 flare-side
Old Jun 5, 2007 | 08:31 PM
sportred's Avatar
sportred
19-92 flare-side
Hi I am new to this site thank you for the warm welcome I just bought a 19-92 Flareside from my brother inlaw this truck has hardly any milage and very well kept it is all stock and I would like to start to add some parts first of a nice sound system can someone point me in the write direction?I would like input on were to put subs and perhaps someone has the same unit and could give me some pointers.
Old Jun 5, 2007 | 08:46 PM
Skandocious's Avatar
Skandocious
I'm afraid we'll need a little more info here. What is the trim on your cab? ie, standard cab (no back seat, extended cab (half back seat), etc. And what kind of head unit do you have right now?
-Chris
Old Jun 5, 2007 | 09:02 PM
sportred's Avatar
sportred
oh sorry reg cab bench seat there is a entry level CD player in it now and old bozoka tub behind the seat I would like to replace with a sub but what will fit behind the seat there is not much room.
Old Jun 5, 2007 | 09:24 PM
Skandocious
By entry level I am assuming that you mean cheap aftermarket deck right.
As for subwoofers, I used to have two 10" subs in separate boxes behind my seats in my 94 reg cab. If you don't want your knees resting inside of your steering column while you drive then you'll want to get the shallowest subs that you can find. Mine are bazooka's but not tubes (bazooka makes non-passive subs). They are very thin. There are special made boxes for single cab trucks that are flat on the back on sloped on the front, to fit between the seatback and the rear cab wall. I had the amp mounted on the wall between the two subs.
-Chris
Old Jun 6, 2007 | 09:20 AM
sportred's Avatar
sportred
yes that sounds like the way to go I will look into those boxses
Old Jun 6, 2007 | 12:16 PM
low92flareside's Avatar
low92flareside
check my gallery. I've got a single 10". I removed the flip down armrest for my bench and got a box that fits right in. amp is behind the seat on the driver side.
Old Jun 6, 2007 | 04:18 PM
Skandocious
Wow thats one that I've never seen before! Can someone still sit there or is it too uncomfortable.
And to sportred, I'll get some pictures of my subs in those boxes this weekend so you can see what I'm talking about, if you haven't found them already.
-Chris
Old Jun 7, 2007 | 05:50 AM
low92flareside
I'm kinda big and its a stick so I'm never really a fan of having someone in the middle anyways...but yes someone can sit there for short trips and it's not bad at all. ya get a nice little massage from the sub too!
Old Jun 7, 2007 | 08:02 AM
96sherm's Avatar
96sherm
lol...massages are good... i had 2 12inch subs behind the seat of my '96 reg cab. i would definately reccomend getting the shallow subs though, sitting that close to the steering wheel is majorly uncomfortable!!
Old Jun 7, 2007 | 08:10 AM
low92flareside
that's why i did it the way i did. i've got to have the seat all the way back just to fit comfortably.
Old Jun 8, 2007 | 11:32 AM
lostin90s's Avatar
lostin90s
Back when I was into the boom . I had a sleeper cap (looks like a truck cap but only 2ft or so deep)
Id remove the back cab window and use camper seal to seal cab/ camper . Built a box under cap for amps ETC You can fit ant sized sups you want int it . I used bet I could bounce quarters on sunroof , Paid for gas . And I could put seat anywhere I wanted it.
Now I wish I had it I'm about deaf LOSt
cryptyx
Apr 27, 2014 08:44 PM
JohnT
Aftermarket Products
Aug 28, 2008 06:10 PM
electod
Feb 15, 2005 08:38 PM
tyson1992
Apr 1, 2004 10:30 AM
