Lowered 1985 f150
Old Jun 5, 2007 | 04:49 PM
gruvy01's Avatar
gruvy01
Lowered 1985 f150
Can anyone tell me what would be the least expensive way to lower my 1985 f150 stepside? Any ideas would be appreciatted.
Old Jun 5, 2007 | 08:39 PM
Franklin2's Avatar
Franklin2
Here's a guy that may drop your axles for around $430.
http://www.roadsters.com/axles/
Old Jun 5, 2007 | 11:19 PM
dmanlyr's Avatar
dmanlyr
How low do you want to go ? On the front - 1 to 1-1/2" (maybe even 2") is probably doable cheaply (cut the coil springs), more than that can and will require some outlay, like the bars/axles mentioned by Franklin 2 above.
The rear maybe a little more, but serious dropping is going to require frame notching.
David
Old Jun 6, 2007 | 06:20 PM
Franklin2's Avatar
Franklin2
I read an article somewhere that you can barely get away with 2 inches of drop with lowering or cut springs. Then you have to go with the dropped axle which gives you about 3 inches, which they said will in total give about 5 inches of drop.
Or you can ditch the whole frontend and put a mustang II crossmember on it. I think fatman fabrications makes one. But that would not be cheap.
On the old 50's trucks they cut the whole front of the frame off and put one from a car on it and drop it that way, but you really have to know what you are doing to tackling something like that.
cw50must
Apr 23, 2018 11:56 AM
Kingcobra1
Engine Swaps
May 9, 2017 10:00 PM
madmom
Oct 2, 2016 07:42 AM
f150rd
Dec 19, 2011 07:55 AM
onetwin
Aug 15, 2006 12:45 PM
