Ih there i am not a big ford person but i have a frined who is and he has a problem he or i can not figure out so here gose he has a 302 the was cooling just fine untill he put on and aftermarket serpintine belt system that required a revirse flow water pump the he put on now he can't keep it cool is thhere a differnts in the timeing /waterpump cover on the revirce flow pump
there are about 500 water pumps for the 302, all with the same part number. His best bet is to go to a junk yard and take some pictures of other setups so he gets it all working good. maybe it has something to do with the heater hose & Bypass. Also, what I did with my 302 was drill some(3-4) 1/4 inch holes in the flange of the thermostat to make additional bypass parts so the engine would run a little cooler.
Question: Did he put the thermostat in the right way? they are directional
Be sure and look over the tech Forums for answers to technical questions. Just click on the Forums tab at the upper left and scroll over the boards. There are several that may be able to help you out.
