ABS light
Old Jun 5, 2007 | 11:15 AM
heterodox1's Avatar
heterodox1
ABS light
A friend just bought a used '98 Expy with 65k miles. On the second day, the abs light came on. Is there an easy way to know what's wrong? Or is this one of those "dealer" problems?
Is this just a code like the CEL? I'm wondering if the dealer he bought from had just reset the light so it would go off until he got the truck home...
Old Jun 5, 2007 | 11:33 AM
heterodox1's Avatar
heterodox1
I should have searched before I posted my question. It seems the most common cause is the speed sensor mounted on the rear diff - is that right? What else could it be?
Old Jun 5, 2007 | 11:53 AM
sowder's Avatar
sowder
Mine came on when I was a little low on brake fluid? worth a look
theres a float in my master cylinder that sometimes sticks down
Old Jun 11, 2007 | 12:59 PM
NaviShock's Avatar
NaviShock
Mine came on and it was the speed sensor. It was 26 bucks from the dealer and took maybe 5 minutes to switch out. Problem solved.
Old Jul 19, 2007 | 02:04 PM
RomanX's Avatar
RomanX
did your ABS light go out as soon as you guys replaced the sensor?
Old Jul 19, 2007 | 04:13 PM
scottspoerry's Avatar
scottspoerry
the rear sensor is sort of on top of the differential. It is REALLY easy to replace. Even if it isn't the problem it's worth the bet, just for the chance of avoiding a couple of hundred bucks to the dealer in diagnostics and labor costs.
Old Jul 19, 2007 | 05:51 PM
projectSHO89's Avatar
projectSHO89
Before possibly wasting 25 bucks, pull the flippin sensor and check it with an ohmmeter. Dead ones are always open. Good ones are around 1.2K.
Steve
Old Jul 19, 2007 | 08:53 PM
RomanX's Avatar
RomanX
I have an 03' 2wd.. I can't seem to find where the sensor is at. I've felt all around on top of the pumpkin and i dont feel anything that looks like the sensor I have.
edit:... here are some pictures I've taken with my phone. I appologize for the quality
Old Jul 20, 2007 | 07:42 AM
bigwillie23's Avatar
bigwillie23
My ABS light is on too. Where's the sensor?
If anyone can tell me where the sensor is located, or even what it looks like, I'd appreciate it! 2001 Gator
Thanks
Old Jul 20, 2007 | 01:09 PM
Bulldozer's Avatar
Bulldozer
It's located on top of the rear dif, It's held in with one 10MM bolt
Old Jul 20, 2007 | 10:41 PM
RomanX's Avatar
RomanX
man I feel like such a putz... I can't seem to find it. is it right on top of that lip in the 2nd picture that has all the bolts around it?
Old Jul 23, 2007 | 07:05 PM
ArgoExpedition's Avatar
ArgoExpedition
If you follow your driveline to where it attaches; then follow on top of the pumpkin you should find a plug about half way between the "pinion" (end of the driveline) and the back of the housing. It should be fairly obvious, with a plug and two wires. You may not be able to see it, but if you run your hands on the top of the housing you should be able to find it.
Good Luck
Steve
Old Jul 28, 2007 | 02:49 AM
RomanX's Avatar
RomanX
I'm not sure if you're the same Steve that answered my other post... but for the sake of throughness.. .i guess.. I'll add the conculsion of this problem here. The other Steve... (assuming you're not the same one) checked the service manual for the 03+ expy/nav and found that they use 2 abs sensors. One on each wheel. No longer are they on the pumpkin. ...
Thanks guys for all your help and quick response... This is why I love coming here.
RX
