79 Camper Special
Old Jun 5, 2007 | 11:08 AM
Krucible F250's Avatar
Krucible F250
79 Camper Special
Gentlemen,
Firstly, this is my first posting, so I am looking forward to some good reading.
Secondly, I tried to see if my question has been answered elsewhere, so I would not waste your time answering yet another 'same old question'.
I have had a 79 Camper Special for sometime and personally have not seen to many like it and I was wondering if they (Ford) made a number of them in this configuration or rather was this a common factory built configuration:
Model Year: 79
Series: F250 - 4x2 Chassis & Cab
Engine: 8 Cyl, 460ci (7.5L) 4bbl
Assembly Plant: San Jose
Transmission: Automatic, Ford C6
Front Axle: P.S.
Rear Axle: 4.10 5300lb Dana 60
</pre>
Thanks in advance to your answers.
Krucible
</pre>
Old Jun 5, 2007 | 11:10 AM
Jermafenser's Avatar
Jermafenser
Ford doesn't do this configuration since it's a chassis/cab.
Ford made the chassis and cab, then shipped to a RV company to fit the camper body on the chassis.
Is this what you have? A camper bolted down to the chassis, rather than in the factory bed?
Old Jun 5, 2007 | 11:31 AM
Krucible F250
No Sir, there is no camper attached to the truck. The model is a F250 Camper Special.
Krucible
Old Jun 5, 2007 | 11:42 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Krucible
Welcome to FTE
A Cab & Chassis configuration comes without a bed. Post the VIN...that will answer the question if your truck was shipped as a Cab & Chassis, or with a Styleside bed.
For the record: Camper Specials used Styleside beds only. A Cab and Chassis or a Flareside is not a Camper Special.
Old Jun 5, 2007 | 11:55 AM
Mil1ion's Avatar
Mil1ion
To answer your question.
Yes they made thousands of them.
I want to see the VIN because some people don't know what chassis cab means.
Camper special standard equipment.This includes the Styleside bed. ( not chassis terminology)
l
Old Jun 5, 2007 | 12:04 PM
Krucible F250
VIN Number is:
F25JREG0117 Also, the package shown above is the 'Camper Special' I am referring to.
Old Jun 5, 2007 | 01:02 PM
Mil1ion's Avatar
Mil1ion
So you have a styleside box as well ?
you see F25 is NOT a chassis cab code.
F27 is.
You can see everything here on my page.
http://www.clubfte.com/users/mil1ion...ruckCodes.html
What is the 3 rd digit in the BODY Code on the rating plate.
It should be a 4.
I also find that 4.10 gear a little tall for a 460.
3.54's or 3.73's would be plenty
You should be able to drag a ship across the desert with that combo
Old Jun 5, 2007 | 01:06 PM
NumberDummy
VIN Number is:
F25 = Series Code = F250 2WD PICKUP. A pickup is defined as having a bed, a Cab and Chassis is not what your truck was shipped as.
If your truck was shipped as a Cab and Chassis, the series code would be F27, not F25.
Post ALL the numbers off your VIN plate. Mil1ion and I can decode all the info. Mil1ion is a faster typist, and has refs at the ready, so he'll prolly beat me to it.
I'm using microfiche . He's not....
Old Jun 5, 2007 | 01:42 PM
Krucible F250
VIN Plate Information
Here is the VIN Plate Information:
WB - 133, Color - B, GVW - F253, Body - DR4, Trans - K, Axle - 24J, MAX GVWR - 07900, USO - 74
Thanks again guys. So was this a common configuration?
Krucible
Old Jun 5, 2007 | 01:57 PM
NumberDummy
off the cuff...so I don't have to squint at a microfiche slide!
Axle 24J
24 = 4.10-1 Rear axle ratio, Dana 60, 5300 lb axle capacity.
J = Power steering
DSO = 74 = Seattle...the truck was ordered from the Seattle Zone Office.
Old Jun 5, 2007 | 02:02 PM
Mil1ion's Avatar
Mil1ion
Plus I have my memory
133 - 133" Wheelbase
Body - DR4,
D - Kint & Vinyl bench
R= Jade in color
4- Styleside box
Trans - K, - automatic = C6
Common...except for the 4.10 Rear axle - Yes !
from my page I linked to..you can see the axle ratio options.
Old Jun 5, 2007 | 02:55 PM
NumberDummy
133 wheelbase, and the K trans code, I knew off the cuff, too...but I figured you'd beat me to it, since I'm the world's worst typist...and have to correct all the typos, so I posted what I could, as fast as inhumanly possible.
Old Jun 6, 2007 | 11:03 AM
loudfords's Avatar
loudfords
What's Kint?
Old Jun 6, 2007 | 11:50 AM
Jermafenser
Originally Posted by loudfords
What's Kint?
Chain-mail pattern on the inserts.
Old Jun 6, 2007 | 01:38 PM
loudfords's Avatar
loudfords
Ah, ok, thanks. The 79 truck brochure and 78 explorer brochure just call it chain mail.
