Sponsored by: Real Truck
warning bells
Old Jun 4, 2007 | 08:38 PM
Murfman's Avatar
Murfman
warning bells
Not sure if this has been brought up, but a coworker has an 05 F250 and the warning bell keeps on dinging with his door open and his keys are out of the switch. It keeps dinging until he closes the doorMy 05 F250 don't. Is that normal? And can you shut it off?
Old Jun 4, 2007 | 09:02 PM
F250tuff's Avatar
F250tuff
There is a wire in the steering column you can cut and that will disable the chime. Did you buy yours used? If so, the previous owner probably cut that wire.
Take a look at this post. About half way down, Beerstalker gives very good details on how to do this:
https://www.ford-trucks.com/forums/5...=chime+disable
Old Jun 4, 2007 | 10:33 PM
Beerstalker's Avatar
Beerstalker
Like F250tuff said, if it is dinging all the time then most likely it is the key in ignition wire shorting out somewhere.
Old Jun 6, 2007 | 06:45 AM
Murfman's Avatar
Murfman
The coworker and mine were brand new. His chimes all the time and mine only when the key is on. Thanks for the info will relay it to him. Gonna tell him to take it to dealer and have them fix it.
Old Jun 6, 2007 | 10:55 AM
johnnysF350's Avatar
johnnysF350
It is not normal, he needs to take it in to get it repaired unless he wants to take the above recommendation and diable it completely. I have seen this happen from time to time, usually on older vehicles. The contact in the ignition cylinder that gets triggered when the key is inserted is probably stuck so it thinks the key is in all the time.
Old Jun 9, 2007 | 10:20 PM
F250tuff's Avatar
F250tuff
I apologize Murfman. I mis-read your original post, and thought it said "while the keys are in the switch". As others have said, there is a problem somewhere and he should either have it looked at or disable it completely. If is is still under warranty, I would have it repaired, as who knows what is causing it and what else it may start affecting later.
Old Jun 10, 2007 | 09:32 AM
Murfman's Avatar
Murfman
Thanks for the info. I thought there was something wrong also and told the owner to get it checked. Haven't talked to him since. Am curious to what it was.
tc0nn
Feb 19, 2014 03:53 PM
peasel_85
Feb 19, 2008 08:09 PM
RDC F250 7.3
34
Dec 7, 2007 10:25 AM
mrpaintman
Mar 23, 2007 08:47 PM
trencherman
Mar 7, 2005 11:19 PM
