Ranger wheels
Old Jun 4, 2007 | 08:33 PM
Moyerboy's Avatar
Moyerboy
Ranger wheels
I am new to the ranger department I just bought a 1994 ford ranger with a 3.0L 6 4x4 with 60,000 and i was wondering if anyone knew if the bolt pattern was the same as a 94 f-150 with the 300 6 in it I would also like to know if there are ne bugs i need to look for in these trucks
Old Jun 4, 2007 | 08:58 PM
racsan's Avatar
racsan
bolt pattern on the ranger is 5 on 4-1/2, the F150 is a 5 on 5-1/2. you didnt say which trans you have, the manual has potential for shift-rail plug leakage, keep a eye on fluid level. if you have auto hubs, they sometimes will give you problems. the 3.0 motor is a good, long-life engine, its only fault is that it makes its power higher in the rpm powerband, gotta wind the squirells out of it a bit. low gearing helps (4.10 preferably) some have had trouble with the shift motor on the electric-shift transfer case. mine has had no problem there. for the most part, keep it maintained it it will last longer than you may want it to.
Old Jun 5, 2007 | 06:16 AM
Moyerboy's Avatar
Moyerboy
ok thanks and it is the automatic transmossion so far it jsut seems to have a hard time running when its cold and it shifts really hard out of 1st into 2nd. And f-150 wheels wont work damn i had a set with tires and all i was going 2 get off a freind for 100 bucks oh well
