Oasis Request Please
Old Jun 4, 2007 | 01:06 PM
Brian_Eyler's Avatar
Brian_Eyler
Trailering
2005 Excursion 1FMNU41S95EA31108
Thank you
Old Jun 4, 2007 | 05:23 PM
ranger88a's Avatar
ranger88a
VIN VEH LINE MKT DERIV BODY CAB VER SERIES DRIVE TYPE PLT CD TRS CD ENG CD PROD DATE WARR DATE SELLING DEALER SELL CNT TIS WCC CPSC_6 PREF BASE SUFF CCC CD DIST(Miles)
1FMNU41S95EA31108 T/L1 F T/WD T/BD T/E A1 T/DE T/WA 29-JUL-2004 20-JAN-2005 127039 USA 0 7D02 170301 * 13404 * G29 42 5
AWS Claim Key: 53631 Trx Code: 1 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 00068 - * Name: BOB BELL FORD Ph: 410-7663600 St:MD Ctry Cd: USA Reg Cd: NA Repr Date:23-AUG-2004 Doc #:616133A
Cust Comments: LEFT REAR BRAKE LIGHT OUT
Tech Comments: 8 CHECK CONNECTOR AT TAIL LIGHT N C CONNECTOR 4035 NO PLUGGED IN ALL THE WAY, STRAIGHTEN PIN AND CONNECT PLUG PROPERLY AND TEST.OK
1FMNU41S95EA31108 T/L1 F T/WD T/BD T/E A1 T/DE T/WA 29-JUL-2004 20-JAN-2005 127039 USA 0 7W15 011902 3F2Z 15K859 BA A85 42 10
AWS Claim Key: 211438 Trx Code: 1 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 00068 - * Name: BOB BELL FORD Ph: 410-7663600 St:MD Ctry Cd: USA Reg Cd: NA Repr Date:14-DEC-2004 Doc #:617844A
Cust Comments: CHECK FOR REAR BACK UP SENSORS ARE INOP
Tech Comments: 10 REAR BACK UP SENSOR INOP WARR REAR BACK UP ALARM INOP RAN WDS TEST FOUND BOTH SENSORS ARE OUT OF SPEC R&R BUMPER REPLACE BOTH REAR SENSORS AND RETESTED OK
1FMNU41S95EA31108 T/L1 F T/WD T/BD T/E A1 T/DE T/WA 29-JUL-2004 20-JAN-2005 127039 USA 5 6J14 011404 * 218A42 * L17 07 2937
AWS Claim Key: 1116959 Trx Code: 2 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 00072 - * Name: KEYSTONE FORD Ph: 717-5972103 St:PA Ctry Cd: USA Reg Cd: NA Repr Date:14-JUN-2005 Doc #:137670B
Cust Comments: CUSTOMER STATES THAT P S REAR DOOR LOCK IS INOP
Tech Comments: 2937 CHECK OPERATION OF R REAR DOOR LOCK REMOVE DOOR PANEL FOUND ACTUATOR CONNECTOR NOT POSITIONED PROPERLY INSTALL CONNECTOR REINSTALL DOOR PANEL
2005 EXCURSION BODY STYLE
XLT 4 DR WAGON 4X4 ENGINE
6.8L EFI SOHC
TRANSMISSION
4R100 (E4OD) 4SP O/D AXLE CODE
C1 ENGINE CALIBRATION
4L110A
NO WARNING MESSAGES FOUND FOR THIS VIN
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
01/20/2005 BUILD DATE
07/29/2004 SALE MILEAGE
OUTSTANDING FIELD SERVICE ACTIONS
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
NO RECENT REPAIR HISTORY ON VEHICLE Is this what you needed?
Old Jun 4, 2007 | 06:42 PM
Brian_Eyler
Trailering
Thank you very much. That's what I needed. Is there a way I give you a rating or something?
Old Jun 7, 2007 | 04:28 PM
ranger88a's Avatar
ranger88a
No, thanks is enough. Your welcome.
Aerostar
Aug 21, 2024 11:23 PM
bradphx
67
Jan 10, 2024 06:12 PM
Mar 9, 2016 12:40 PM
miko6810
Modular V10 (6.8l)
Jun 4, 2014 06:14 AM
Roachfood
Mar 11, 2002 10:21 PM
