Computer Chips & Tuners
Pinging noise w/SCMT installed
Old Jan 3, 2003 | 05:12 PM
fred m lewis's Avatar
fred m lewis
Ken,with the SCMT 60hp program installed there was a pinging noise (more like the Lawrence Welk bubble machine) whenever I pulled a load up a grade, even an overpass. The PCM code was PMT2 but was reflashed (new code not identified)on advice from Super Chips tech. The noise is still evident. If I disengage cruise control and manually downshift the noise is eliminated. Any ideas?
Fred
Old Jan 5, 2003 | 01:19 AM
FTE Ken's Avatar
FTE Ken
Is it the wastegate you're hearing? Describe in detail what the noise is, you may be hearing normal wastegate noise.
Old Jan 5, 2003 | 01:22 AM
FTE Ken's Avatar
FTE Ken
