Can Late Model Wheels Work?
Old Jun 3, 2007 | 09:31 PM
thetmaxx's Avatar
thetmaxx
I Scored a set of Late Model Wheels for cheap today! I know there is a bolt patern difference that changed somewhere in the 90's, So I don't need that information.
My question is if anyone has ever had these wheels modified to fit? Can that be done? Or how would one modify the truck's lug pattern to the modern metric size.
I'm just throwing this out there to people who have done this kind of thing before. If you have useful information, Thank you in advance!
Old Jun 3, 2007 | 10:15 PM
Jermafenser's Avatar
Jermafenser
Spacers is my best guess.
You could, but um, WHY?
Old Jun 3, 2007 | 10:17 PM
bucks77ford's Avatar
bucks77ford
I believe the bolt patterns work up to 96.
Old Jun 3, 2007 | 10:32 PM
75F350's Avatar
75F350
Adapters are available, but they cost quite a few dollars. Even trying to change the bolt pattern on the hub is going to cost some money.
Adapters cost $100.00 each, and a set of hubs with new studs just over that.
A nice new set of wheels can be bought for the same or less than $100.00 ea.
Even if you got new late model wheels for free, it would cost more to bolt them up than new ones would. Ones that actually fit.
Old Jun 3, 2007 | 10:55 PM
thetmaxx's Avatar
thetmaxx
Yeah, I think I will try to resell them, and put the money directly towards a new set of wheels with the correct bolt pattern. I found an old post where a member said he knew a shop that could put steel inserts in and re-do the pattern. I wonder how that would work. But I don't think I will bother anyways...
Old Jun 6, 2007 | 07:29 PM
thetmaxx's Avatar
thetmaxx
OK, so These are the wheels, I've looked into adapters, they are pricey, but there aren't many aftermarket wheels catching my fancy. So being one that always has to have other's approval what do you think of these wheels? Sorry if this is a pic of your truck, it's how mine should look when done (but slightly less 4x4ish)
Do these look like they are worth it? BTW with the 2" adapters, the wheels will fit just inside the fender wells, so they should look ok.
Old Jun 6, 2007 | 07:46 PM
lostin90s's Avatar
lostin90s
I believe the SD trucks 8 Bolt lasted a few more years as I know people running these on older style 90's truck
Old Jun 6, 2007 | 08:05 PM
AZ_Catskinner's Avatar
AZ_Catskinner
I've seen the later style steel wheels on earlier trucks, so you shouldn't have any problem (in theory) just bolting them on.
Old Jun 11, 2007 | 10:37 PM
LedheadELH's Avatar
LedheadELH
I don't know about the 8-lug but the 5-lug is DEF. different. it is Very close but doesn't work, I've tryed it already.....sorry AZ
Old Jun 11, 2007 | 10:53 PM
AZ_Catskinner
I was referring to the 8 lug - I never even thought of the late 5 lugs or swapping them to an older truck.
Old Jun 11, 2007 | 11:03 PM
LedheadELH's Avatar
LedheadELH
Old Jun 11, 2007 | 11:52 PM
unrulee's Avatar
unrulee
5-lug will work, SD wheels WILL NOT! Ford went to a metric bolt pattern in 99 for the new Super Duty's. The wheel's won't fit the old standard 8 on 6.5" pattern.
Old Jun 12, 2007 | 06:54 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
F150 15" wheels went metric in 1997. They will not work on older trucks with the 5.50 bolt pattern.
Old Jun 13, 2007 | 01:12 PM
ChaseTruck754's Avatar
ChaseTruck754
yes - F-150 wheels went from 5x5.5" to 5x135mm in 97, and the 8 lugs changed in 99.
You don't HAVE to run a spacer to run these wheels. From the pic they look like they are the aluminum wheels off an excursion. If so you can take them to a good wheel place and they should be able to drill them and use steel inserts to change the lug pattern. We do this to run the nice alcoa wheels everybody takes off of the newer superdutys on the older fords and chevys.
If I remember correctly it costs about $25 per wheel.
twofifty
Jun 20, 2016 06:07 PM
MyX4Camping
Jul 14, 2015 05:52 PM
vrr
17
Jul 26, 2011 10:02 PM
zerocool420
Engine Swaps
Jan 22, 2009 12:56 PM
scroller bill
1978 - 1996 Big Bronco
13
Nov 19, 2007 09:24 PM
