Oil Drain Plug leaking - notorious problem?
Old Jun 3, 2007 | 09:14 PM
billygoat's Avatar
billygoat
I just changed the oil in my X (90K) and now it drips from the plug. I noticed when I drained it, that it had a nylon/plastic washer that was damaged. I went to the dealer to replace it and they gave me a copper washer for the plug and said this was correct. The manual states to torque the plug to 6 ft lb. After pouring in the new oil in, it began to show signs of dripping. I went back to the dealer thinking that maybe the plug/bolt was incorrect. It appeared so when I got the new one. I drained the oil again, put in the other drain bolt with another new washer, torgued it correctly and it still drips. I just power washed the driveway and now have spots again! I am afraid to torque it any tighter in fears of stripping the threads. Should I find another washer? Any suggestions are appreciated.
Old Jun 3, 2007 | 11:18 PM
shadowdd's Avatar
shadowdd
Does the pan look damaged in anyway? I do know that the copper washer is correct on the factory pan. You could always us this as an oppertunity to upgrade to a larger pan that dissipates heat better.
Bryan
Old Jun 4, 2007 | 12:16 AM
1's Avatar
Autozone or other parts stores usually stock a slightly oversized thread oil pan plug. If yours is stripped this would be the first thing to try. Im guessing your threads are bad or it just needs more torue. Dont go crank on it and blame me if it strips though! lol
Old Jun 4, 2007 | 01:29 AM
billygoat's Avatar
billygoat
I do not believe that the threads are stripped at this time, and the pan looks almost new - no damage.
Who makes a bigger pan (as if 15qts weren't enough!)
I picked up the two replacement washers at two different Ford dealers and both provided the same copper washer.
I may have to try and locate another plastic/nylon type washer or start to gradually increase the torque until it hopefully stops dripping.....
Keep those ideas coming.....I appreciate it!
Old Jun 6, 2007 | 09:46 PM
igotoneforya's Avatar
igotoneforya
maybe i am just lucky, but i put all i can into tightening the drain plug...i am only 160 lbs but there is not enough room for too much leverage and a 10 inch ratchet helps me not overtighten, but I am sure it takes more than 6 lbs to remove it and i put more than 6 ft lbs on all I replace...always room for another 1/4 turn
Old Jun 6, 2007 | 10:01 PM
Beachbumcook's Avatar
Beachbumcook
Got Diesel?
Just tighten the darn plug with the copper washer as tight as you can.
The copper washer compresses to seal and works for 1 - 3 oil changes... but 6 pounds of tourque hardly sounds like enough. It will not strip!!
Good luck,
Old Jun 6, 2007 | 10:34 PM
billygoat's Avatar
billygoat
I initially reported the 6 Lbs incorrectly....it actually stated 6Nm (Ford factory manual vol.2), which as you know, is a lot less then 6Lbs.....
As you have both advised, I will crank on that plug....thanks!
Old Jun 7, 2007 | 12:12 AM
Stewart_H's Avatar
Stewart_H
Fumoto valve, and never worry again.
www.fumotovalve.com
I put Fumoto valve's on all my Fords.
Stewart
Old Jun 8, 2007 | 11:48 AM
exposition's Avatar
exposition
I solved my drip problem by putting a very small dab of rtv on the faces of the copper gasket .
mbeards
13
Oct 6, 2015 11:30 PM
F250_
17
Feb 12, 2015 09:46 AM
Ian123
Apr 19, 2012 10:29 AM
01raptor
19
Nov 17, 2011 08:51 AM
Bopper
Jul 12, 2009 08:00 PM
