Well heres whats up. I changed my oil and Spark Plugs before I went on a 4.5-5 hrs trip to inlaws. After about an hr, I noticed my temp was lower than what it was running at before the services. (this is the first time I changed the plugs in 3 yrs. bought truck June of 04.) Unfortunately my guage doesn't have numbers, onlt the word NORMAL. Before I would normally see the needle around center of the word. However now it's not even over the "N". I know that it's good to have a cooler engine, but can it be too cool? Should I be concerned? On the way back it was cool too, and I was loaded down a bit. I wasn't Mountain driving but I still had a few good sized hills, the warmest I saw it was just the corner of "N". Hope this is a good thing! Any thoughts are welcome.
I don't see any connection between what you did and the different temperature.
I guess it just picked NOW to act up.
If this is fuel injected, cooler is BAD because the computer senses the engine still needs a rich mixture = poor gas mileage.
If carbed, not a biggie.
The first component we always suspect in this scenario is a faulty thermostat...theyre cheap and prone to failure.
My father bought his 95 new with no miles on it, and since the day he's had it the thermostat has read right on the N. It hasn't ever went any farther after it has warmed up and he has 168K miles on it and still runs like a top.
I don't know if it was messed up when he bought it or not, but he's added a couple thermostats an it hasn't changed.
It is EFI. SO I should have my thermostat checked out? How can I do that myself?
Yep. Pull it out and put it in a pan of water on the stove along with a thermometer in the pan to read the water temp. Suspend the thermostat on a piece of wire so that it doesn't touch the bottom of the pan. Watch and see at what temp it starts to open and when it is fully open...or if it's stuck open.
Both my 82 and 86 hardly see the middle of the gauge. In my 96 the gauge moves quite a bit. when its warm it'll climb to about halfway, thermostat opens and it drops to below "N", climbs back up and drops again. Dose this maybe twice a minute when warm.
I'm with andym on this one, thermostats are cheap try a new and see what it does.
When you replace the thermostat be REAL carefull and make sure the new 'stat is laying correctly in the block housing. I don't know why Ford made it fit against the front of the block instead of on top of it like an 8 cyl.
Put a LITTLE black silicone on it to hold it in snugly.
I was stupid and tried to replace the housing piece on and the 'stat slipped down and I cracked my housing. That was without the silicone.
