Sponsored by: Auxito
!!!Front Shocks 2002 F150!!!
Old Jun 3, 2007 | 01:11 PM
Adad2girls&aTruck's Avatar
Adad2girls&aTruck
Angry !!!Front Shocks 2002 F150!!!
What size wrench do I need to change the front shocks? OEMs are double-nutted....WHAT IS THE TRICK TO GETTING THE TOP NUTS OFF???
Old Jun 3, 2007 | 02:13 PM
ReAX's Avatar
ReAX
Should be about 9/16 or 13mm. Hold the bottom nut and spin the top, it's a jamb nut the first nut holds tension, the second one secures the first. If you are trashing them, you have the sawzall option available.
Old Jun 3, 2007 | 02:16 PM
Adad2girls&aTruck
i tried 3/4" too small and 7/8" too big.....maybe a 13/16"?? i don't have that one, so wanted to make sure before i ran out and got one. new shocks came with new top nut, so will need to use the one of the old ones.
Old Jun 3, 2007 | 02:48 PM
ReAX's Avatar
ReAX
It going to be metric then. Try 23 or 24 mm.
Old Jun 3, 2007 | 04:47 PM
Adad2girls&aTruck
OK......managed to get the top nut off........how do you get the shock out from inside the spring if the bottom nut is still on which is keeping the washer/disc on??
Old Jun 3, 2007 | 05:02 PM
ReAX's Avatar
ReAX
I don't know what mount you have, but it should just unbolt and drop straight down. I would expect you to have a 2wd and the lower mount is a bar with two bolts. Those two bolts should be holding anything but the shock.
Old Jun 3, 2007 | 05:06 PM
Adad2girls&aTruck
it's 2wd but there is not enough room between the lower mount and the ground that i can slide the shock all the way out. if i took a picture and sent it to you, do you think that would help.....i'm in serious need of advice to get these changed.
Old Jun 3, 2007 | 05:27 PM
ReAX's Avatar
ReAX
You will need to get the front end off the ground enough to clear them. Another trick you might try, depending on how desperate you are; if you can't get the truck high enough, make the ground lower. Dig out enough so that the shocks can drop all the way out.
Old Jun 3, 2007 | 05:32 PM
Adad2girls&aTruck
yeah....it's desparation time, but rain is on the way, so i'll try it tomorrow...just hate that i have to thread that top nut all over again so that i can go to work!
Old Jun 3, 2007 | 06:51 PM
LxMan1's Avatar
LxMan1
Mine were 18mm.
Old Jun 4, 2007 | 06:09 AM
Adad2girls&aTruck
I wound up using a 20mm on the bottom and turning the top with a 7/8. going to put it on ramps tomorrow to allow me to get the shock out.
I bought the Monroe Sensa-trac shocks (as i did for the rear), but I noticed that they only come with one nut. Do the OEM nuts fit the stem on the Monroe's?? Will more than likely reuse the nuts, bushings and busing caps/washers from the OEMs when I install the Monroe's.
Old Jun 4, 2007 | 12:20 PM
LxMan1's Avatar
LxMan1
The shafts are probably a different thread.
Old Jun 4, 2007 | 12:34 PM
Adad2girls&aTruck
then what should i do about what was supplied with the Monroe shocks (which were recommended by several people) being that they only supplied 1 nut???? basically the bottom nut on the OEM is bottom out on the shaft......is it necessary to replace this one with the new Monroe shocks?
Old Jun 4, 2007 | 01:21 PM
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD
The monroe's didnt fit my truck for sour apple S***... those were the worst thing i ever did for my truck... the bushing on them dont fit either, and they tend to rattle because of that...
OEM all the way..better ride and they last longer... only got 30k out of my monroes... had 100k+ on my original factory shocks
Old Jun 4, 2007 | 01:43 PM
Adad2girls&aTruck
i'm at 105k and just replacing my shocks...front and rear...but monroe on back, i guess will look into how much the OEMs are.
