1993 ranger ignition switch replace
Old Jun 2, 2007 | 09:14 PM
wusit2ya's Avatar
wusit2ya
Question 1993 ranger ignition switch replace
How do you change an ignition switch on a 1993 ford ranger , i pulled the plastics around the coluum off but dont see how to release the switch with the key in ?
Old Jun 3, 2007 | 01:07 PM
87 XLT's Avatar
87 XLT
Look for a hole on the underside of the steering column. Turn the key to "run" shove a small screwdriver into that hole to press against the spring loaded pin & pull the lock cylinder out.
Old Jun 3, 2007 | 01:14 PM
wusit2ya's Avatar
wusit2ya
Talking Changeing ingnition switch
I had to remove steering wheel and remove tilt steering mec. to be able to get to a two inch long tube that reaches the ignition switch to release it . took about an hour to change out and put back together.
1993 ford
May 8, 2017 08:58 PM
medicpg
Jun 28, 2007 01:01 PM
rio3
Mar 22, 2004 09:23 PM
Moto-XXX
Oct 20, 2003 06:01 AM
digger880
Jun 29, 2003 10:14 AM
