Gas Tank Blues
Old Jun 2, 2007 | 04:48 PM
88-150's Avatar
88-150
Gas Tank Blues
Hi = i have an '88 f150 2wd with the 302. Here's my question. If i let the gas tank go below 1/4 a tank, the truck stalls and wont start up again. I have had the truck to a repair shop and a bunch of parts were replaced but the problem is still there. Any suggestions? I'm running 87 octan on the rear tank(front one went bye-bye) withch is clean as new(the sensor/pump/screen are clean as well).
I'm at worlds end on this one,
Matt
Old Jun 2, 2007 | 05:17 PM
94broncoxl's Avatar
94broncoxl
How dou yo get it to start up again/how long does it take before she fires up again?
Old Jun 2, 2007 | 05:31 PM
lostin90s's Avatar
lostin90s
Well if you have to put gas in it to start. Maybe you guage is off. The one in ,my parts truck sometimes shows a 1/4 but you can run it empty.
Or dose it start right back up.
Old Jun 2, 2007 | 11:33 PM
88-150's Avatar
88-150
i usualy have to spend about 20 min repriming the line and i dont think its my gauge(how would i be able to tell?)
-matt
Old Jun 3, 2007 | 06:37 AM
fmr9's Avatar
fmr9
Should be able to tell about the gauge by the amount of gas it takes to refill the tank.
This kind of reminds me of my sister in law. They got a new car. They lived next door to a gas station, but drove a lot of miles everyday. She ran out of gas three times in the first two weeks. She said" I don't understand it. In the old car when the gauge got to empty, I could make two more trips into town, but when this one gets to empty it IS empty." This woman is an intensive care nurse. Got peoples life in her hands daily. Scarey thought ain't it.
Old Jun 3, 2007 | 06:52 AM
hogdogs's Avatar
hogdogs
That nurse needs a "reserve" petcock like a bike has!
Brent
Old Jun 3, 2007 | 07:38 AM
88-150's Avatar
88-150
well - this aint no new truck. It gets down to just below(a hair or lower) and then it stutters and stalls. I've never ran into this problem in all my time owning a ford truck.
-matt
Old Jun 3, 2007 | 09:55 AM
subford's Avatar
subford
Matt
Your in-tank boost fuel pump is not running, either it is not getting power, not grounded or it is a bad pump.
Old Jun 3, 2007 | 10:27 PM
88-150's Avatar
88-150
thanks - thats the most helpful news all day! I'll have to check that now.
-matt
Old Jun 8, 2007 | 11:38 AM
CarbedNotch's Avatar
CarbedNotch
Water Is In Your Front Tank
Old Jun 8, 2007 | 12:18 PM
subford's Avatar
subford
I take it that you did not know that the fuel pump always sucks off the bottom of the tank.
Old Jun 8, 2007 | 12:55 PM
CarbedNotch
so what bill?
does it mean he cant have water in the tank because it picks up from the bottom?
Old Jun 8, 2007 | 06:01 PM
subford's Avatar
subford
so what bill?
No but he said that it runs fine down to a 1/4 tank and gas floats on top of water.
Old Jun 8, 2007 | 10:30 PM
88-150's Avatar
88-150
i dont have a front tank. And if i have water in the tank at that point(when it gets down to 1/4 tank), how do i fix it?
-matt
Old Jun 9, 2007 | 03:24 AM
CarbedNotch
-matt
its simple just lay under the truck and have a look. Its got 2 metal straps holding it up which are held in w/2 bolts. You have to undo those bolts then watch out for the filler neck. its very straight foward. use a floor jack to help lower it slowly especially if there is alot of fuel int he tank.
