Vacuum can be checked with soapy water. Get a spray bottle and shoot around the vacuum lines. You could also have a chance to listen for any hissing. Hissing can be other things, but sometimes it's vacuum. Also of course check for loose lines.
I had the exact same symtoms on a truck I had recently purchased and found out the previous owner had either cut the 02 sensor wires or had swapped in a junkyard manifold pipe and forgot to install a new sensor, or forgot to splice the wires back together.
I spliced the wires and was good to go.
It is a heated 02 sensor and when they are bad, they don't throw the code till your running down the road a bit.
Check your 02 sensor wiring and connector connection.
There is also a good posibility that the new sensor went bad.
If it was a fuel delivery or vacuum problem, I would expect it to throw the code sooner.
