To all those that use headers...
Old Jun 1, 2007 | 06:57 PM
eco's Avatar
eco
...what do you do with the support brace that goes from the intake plenum to the stock exhaust manifold bolt, the engine dip stick tube support bracket etc. etc. upon installation of the headers and removal of the manifolds????
Old Jun 1, 2007 | 09:06 PM
mrl390's Avatar
mrl390
I took off the plentum support and wire tied the dipstick tube to the plug wires in a way that keeps it from moving around.
Old Jun 2, 2007 | 01:02 PM
wes0354's Avatar
wes0354
I used a stud and mounted it in one of the bottom valve cover mounting holes.
Old Jun 2, 2007 | 01:05 PM
wizzard351's Avatar
wizzard351
i used a peice of threaded rod,screwed it into the head run a nut down on it to tighten the header,then run another nut on then the suport brace then one more nut. it was a pain in the but ,it works ok igess
Old Jun 2, 2007 | 01:36 PM
eco's Avatar
eco
Thats what I would like to do...but ARP does not offer a stud that will allow me to do that and I refuse to use anything but ARP.
Old Jun 2, 2007 | 01:37 PM
eco's Avatar
eco
Explain.
Got any pics??
Old Jun 2, 2007 | 04:10 PM
crappyf250's Avatar
crappyf250
I welded a bolt to the header flange for the dipstick:
As for the plenum support, my headers (ford racing) came with a long bolt with a standoff.
Old Jun 3, 2007 | 12:00 AM
Mr. M's Avatar
Mr. M
I did the exact same thing. Although my bolt is a bit lower. Didn't take much time or effort. It has worked for my rig for quite a while now and the dipstick has yet to wiggle out.
Old Jun 3, 2007 | 01:07 AM
Hawk180's Avatar
Hawk180
I bought a set of new exhaust manufld bolts from NAPA, used the long ones with a spacer, then the stock nuts. It works very well and looks like a factory setup.
Old Jun 3, 2007 | 08:01 AM
DOHC330MustangGT's Avatar
DOHC330MustangGT
What brand headers are you guys using, short or long tube, are they specifically for Ford trucks, and do the shorty headers you used bolt up to the stock Y pipe?
Old Jun 3, 2007 | 08:23 AM
crappyf250's Avatar
crappyf250
Ford Racing shorties (from Summit), and yes they bolt up to the factory Y pipe .
Old Jun 3, 2007 | 08:34 AM
DOHC330MustangGT
Thumbs up
Ohhhhhhhhhhh!!!!!!!!!!!!!!!!!!!!!
So these are specific to these trucks?
Do you have a PN# or link?
Old Jun 3, 2007 | 09:49 AM
Mr. M's Avatar
Mr. M
Yes. These headers are made for these trucks. Go to the summit site and look up the Ford Motorsport shorty headers for the 5.0 and 5.8. Ebay has them as well.
They do bolt up to the factory y-pipe as well. I'd recommend you swapping out the factory Y-pipe with a high performance set. Bassani makes a bolt up version. The factory Y pipe is definitely a choke in the system and if you're not going to run full length headers, you should swap out the restrictive stock y pipe.
Old Jun 3, 2007 | 10:03 AM
DOHC330MustangGT
Thumbs up
Oh yeah!!!!!
Found'um!!!! http://store.summitracing.com/partde...=1#Application
Old Jun 3, 2007 | 10:10 AM
Mr. M's Avatar
Mr. M
[QUOTE=DOHC330MustangGT]Oh yeah!!!!!
Found'um!!!! http://store.summitracing.com/partdetail.asp?part=SUM%2DG9035&view=32&N=700+150+ 4294908309+4294840126+4294907048&appfilter=1#Appli cation[/QUOTE]
I wouldn't buy those headers. The flanges are thin, unfinished and will be a bear to keep from leaking.
The FMS Shorties are 409 stainless, with thick machined flanges, and trouble/leak free.
You get what you pay for.
