Ignition Problems
Old Jun 1, 2007 | 05:33 PM
rdmytro's Avatar
rdmytro
Ignition Problems
I have an 88' F250 with a manual trans and a 7.3 idi. The starter won't crank when I turn the key. I can crank the starter and start the truck if a manually ground the relay. It seems like the clutch pedal won't go down far enough to allow the starter to crank. How can a check the clutch pedal?
Old Jun 1, 2007 | 10:38 PM
PLC7.3's Avatar
PLC7.3
There should be a clutch pedal position switch..... check it for correct attachment to pedal arm.
Old Jun 2, 2007 | 04:40 AM
bilder12's Avatar
bilder12
as plc stated ... the clutch position switch could be goofy and also there is a rod that runs down thru the steering column that activates the switch on the bottom of the steering column that goes goofy too.
Old Jun 2, 2007 | 05:50 AM
shorthair's Avatar
shorthair
P.O. bypassed my clutch switch for which I'm grateful
Old Jun 5, 2007 | 09:06 PM
rdmytro's Avatar
rdmytro
How did you bypass it? Where are the wires for the clutch switch?
Old Jun 6, 2007 | 07:47 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
You'll have to lay down on the floor and look up on the clutch shaft and you will see it. Best not to bypass it as it is a safety switch. I did that on an old car and my son (15 at the time) accidentally started the car and wound up hitting my wife.
