Compression Ratio
Old Jun 1, 2007 | 02:08 PM
cts1954's Avatar
cts1954
Compression Ratio
I was been working on my heads with success so far, I have measured and calculated the compression ratio as it is just above 9:1. What is the ideal compression ratio for a 255 flathead slightly modified. Now is the time to make adjustments if neccessary. Thanks for you input.
wgc
Old Jun 1, 2007 | 02:53 PM
4tl8ford's Avatar
4tl8ford
I think a nice streetable Flatmotor is in the 8.5 - 10 range with all cyl balenced.
Old Jun 1, 2007 | 06:52 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I don't think I'd go any higher than 9:1. Is that including the head gasket volume?
Old Jun 1, 2007 | 07:44 PM
cts1954's Avatar
cts1954
Compression Ratio
Yes, I used .040" as a compressed gasket thickness. Would it run better at 8 or 8.5:1.
Thanks
wgc
Old Jun 1, 2007 | 10:24 PM
4tl8ford's Avatar
4tl8ford
What cam are you running?
Old Jun 2, 2007 | 07:53 AM
cts1954's Avatar
cts1954
It is a 3/4 grind, I believe it is a copy of an Insky Jr 3/4 with around a .5" lift. I made a mistake by putting this cam in and I should have went with a milder one.
wgc
Old Jun 2, 2007 | 07:55 AM
F6Guy's Avatar
F6Guy
depending on your duration but the larger cam might benefit from the higher compession.
Old Jun 2, 2007 | 10:31 AM
4tl8ford's Avatar
4tl8ford
The Isky 400 Jr has a Lift of ,400 and a duration of around 258.
I have a friend running one in a 296 with 10.5 cr in a Roadster, it can get a little touchy in heavy traffic.
Depending on which block I finally use that could be my setup, but I will have an additional 800/900 lbs over the roadster making it a little more friendly.
